[mapserver-users] mapcache seed speed optimization
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Tue Nov 12 08:51:41 PST 2019
Thank Lars.
You can now fetch it from https://github.com/woodbri/imaptools.com
Enjoy,
-Steve W
On 11/11/2019 3:07 PM, lars.schylberg at blixtmail.se wrote:
> Hi
> I have had a similar situation as You with large national data sets in
> shape format. One of the biggest improvements for me has been to split
> large shape files into smaller and
> then use vector tile indexes in Mapserver.
> The tool shp2tile has been working well for me. Stephen Woodbridge has
> written that tool. It can be found at
> http://imaptools.com/download-software.html
> I think that You had to compile yourself on linux, but that was easy.
> I have an example where I have automated this in a script that runs
> through all shape file in a directory and splits shape files larger
> than a certain size and then creates the vector tile index files.
> The code snippet that is part of larger import script can be found here:
> https://gist.github.com/LarsSchy/644b37ab2b1e58b48808bfb2b57d0359
> The script snippet also shows the normal optimizations we do.
> Hope this could give You some ideas how optimize and make Mapserver
> and Mapcache run faster. I also ran into the problem with to many inodes.
> That got solved by using sqlite as backend in Mapcache.
> Best regards / Lars Schylberg
> 11 november 2019 kl. 15:42, "Travis Kirstine"
> <traviskirstine at gmail.com
> <mailto:traviskirstine at gmail.com?to=%22Travis%20Kirstine%22%20<traviskirstine at gmail.com>>>
> skrev:
> I may not be unrealistic for it take mapserver to 4-6 seconds to
> generate 4096px image depending on the amount data being rendered
> and the complexity of your styles / expressions / labels. If your
> mapserver is able to generate a 1024x1024 in under a second that
> is pretty good. Like Jukka and other suggest I would look at
> translating the files to shp files with spatial indexes or postgis
> tables with spatial and attribute indexes if necessary.
> Preprocessing the data (simplification / prefiltering / point
> thinning cluster) and using SCALETOKENs to reference different
> source layers at different scales can lead to big performance
> boosts at the mapserver end.
> For us the biggest limiting factor has been the write blocking to
> sqlite cache when seeding tiles, if you increase the number of
> threads / process in mapcache seed those process will just end up
> waiting to write to the cache. You can generally figure out what
> the max number of processes the cache can handle by running a seed
> on a test area and look at the number of tiles seeded per second,
> as some point -n will have no effect which your process are just
> waiting to write the cache. I would look at using this method to
> test sqlite vs disk or other backends. The GeoTiff cache may be
> promising as it appears to be non-blocking but experimental...
> We use a riak cache with a riak leveldb backend which works well
> for us but is a bit of a pain to manage as it difficult to delete
> objects so it's not great for caches that need to be refreshed.
> Finally you may want to test MapProxy as an alternative to
> MapCache (we use both). MapProxy supports a non-blocking compact
> cache that could solve your inode problem
> Regards
> On Fri, 8 Nov 2019 at 11:48, Sebastiano Laini
> <Sebastiano.Laini at buchanancomputing.co.uk
> <mailto:Sebastiano.Laini at buchanancomputing.co.uk>> wrote:
> We don’t create the data, we rely on OS (ordnance survey) to
> supply us the maps files and then we publish them in our
> service but I assume that probably we will need to create some
> flow to improve it or download it in other format that is faster.
> Sebastiano Laini
> Web Developer
> Buchanan Computing
> *From:*Fawcett, David (MNIT) [mailto:david.fawcett at state.mn.us
> <mailto:david.fawcett at state.mn.us>]
> *Sent:* 08 November 2019 16:41
> *To:* Sebastiano Laini
> <Sebastiano.Laini at BuchananComputing.co.uk
> <mailto:Sebastiano.Laini at BuchananComputing.co.uk>>; 'Rahkonen
> Jukka (MML)' <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>>;
> 'mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>'
> <mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>>
> *Subject:* RE: mapcache seed speed optimization
> For data formats that are slower to read, would it add fit
> your workflow to convert it to different data format before
> creating the tiles?
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
