[mapserver-users] Doubling of labels on high resolution maps
Jan Hartmann
j.l.h.hartmann at uva.nl
Thu Oct 17 07:03:47 PDT 2019
No, neither maxsize nor partials works. I guess that's just the way QGIS
requests large WMS-images.
There is a "tile_metatile_level" configuration directive that should
solve this problem:
https://mapserver.org/output/tile_mode.html
but it does not seem to work for WMS layers.
So I used the underlying PostGIS layer in QGIS, and that works OK, of
course. Not sure if this is a bug in MapServer, though.
Thanks for your help,
Jan
On 10/16/2019 5:55 PM, Rahkonen Jukka (MML) wrote:
> Hi,
> Print composer is probably making tiled requests from WMS. That is
> compulsory for any bigger maps because the default maxsize on the
> Mapserver side is 2048x2048 pixels
> https://mapserver.org/uk/mapfile/map.html. It is easy to increase the
> maxsize but I do not know if print composer as a client can be aware
> of that.
> Partials FALSE may help, but based on the screenshot it is possible
> that print composer is making requests with some overlap.
> -Jukka Rahkonen-
> *Lähettäjä:*mapserver-users <mapserver-users-bounces at lists.osgeo.org>
> *Puolesta *Travis Kirstine
> *Lähetetty:* keskiviikko 16. lokakuuta 2019 18.24
> *Vastaanottaja:* Jan Hartmann <j.l.h.hartmann at uva.nl>
> *Kopio:* MapServer-users <mapserver-users at lists.osgeo.org>
> *Aihe:* Re: [mapserver-users] Doubling of labels on high resolution maps
> There are a few options you could add to your label but I would start with
> MINDISTANCE 200
> PARTIALS FALSE
> See
> https://mapserver.org/mapfile/label.html
> On Wed, 16 Oct 2019 at 10:37, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
> Hi,
> I'm trying to generate high resolution print maps with QGIS, based
> on a MapServer WMS layer. When displayed in the regular QGIS
> application with 72dpi, all looks fine. When using the Print
> Composer based on the same Mapfile, but with 300dpi, some labels
> are duplicated (not all). Some duplicates are clipped. The two
> versions can be seen here:
> https://maps.hisgis.nl/marken_072dpi.png
> https://maps.hisgis.nl/marken_300dpi.png
> Below the Mapfile. Any idea what goes wrong here?
> Jan
> map
> name Markegrenzen
> web
> metadata
> "wms_title" "Markegrenzen"
> "wms_srs" "EPSG:28992 EPSG:3857"
> "wms_extent" "13000 301000 279000 620000"
> "wms_enable_request" "*"
> end
> end
> extent 13000 301000 279000 620000
> units meters
> size 400 400
> resolution 300
> defresolution 72
> projection
> "init=epsg:28992"
> end
> z
> layer
> name Markegrenzen
> status on
> type polygon
> connectiontype postgis
> connection "dbname=ov options='-c search_path=horigheid,public'"
> data " the_geom from (
> select gid,the_geom,naam from markegrenzen
> ) as foo using unique gid using srid=28992
> labelitem "naam"
> class
> style
> outlinecolor 255 0 0
> width 1
> end
> label
> color 255 0 0
> size 4
> end
> end
> end
> end
> <mailto:mapserver-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191017/8f8daf1e/attachment-0001.html>
