[mapserver-users] Mapserver TabFile Error
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Oct 25 09:46:47 PDT 2019
Please include the request that your application sends for Mapserver. You should find it from the access log of your Apache server if you cannot capture it from the client side.
Somehow it feels like your client does not send the &map= parameter, or it you have tried to configure a default mapfile on the server side it did not go right.
Test with no mapfile:
https://demo.mapserver.org/cgi-bin/mapserv?
Test with mapfile pointer included:
https://demo.mapserver.org/cgi-bin/mapserv?map=/osgeo/mapserver/msautotest/world/world.map
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta StefanWebViewer
Lähetetty: perjantai 25. lokakuuta 2019 17.28
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Mapserver TabFile Error
We would like to render a polygon on our mapserver. Everything works wonderfully on our localhost. Now we would like to send the application via external server. Everything works fine on the external server as well.
Except that the polygon appears on the map. The polygon is a TabFile. All paths have been updated, adapted and checked several times. In the network analysis comes with the "map" .exe this error: "No query information to decode. QUERY_STRING is set, but empty." Someone an idea what else would have to be adjusted?
Thanks a lot!
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
