[mapserver-users] WMS-T with daterange attribute
pe_lord
pe_lord at protonmail.com
Wed Apr 8 16:50:10 PDT 2020
I have a time enabled dataset containing various attributes, 3 of them are
related to time. The temporal steps between the records are not constant...
The dataset presents roads history. There is many overlap inside this
dataset.
1st attribute = start_date
2nd attribute = end_date
3rd attribute = period_valid [start_date,end_date]
Here what i've tried:
1- Generate a step constant temporal dataset (e.g. create a geometry for
each date I want to publish by wms-t, and join the geometry (and attribute)
where the step intersect the period for each records). Then my dataset pass
from 250K to 11M records..
2- Keep my original dataset and let mapserver manage the temporal
intersection between the user's provided date AND the period (period_valid).
In this ladder situation, mapserver send me this error:
PGRES_FATAL_ERROR (7)
Error (ERROR: operator does not exist: daterange >= timestamp with time
zone
LINE 1: ...92 321002.819068926))',3798) and ("period_valid" between da...
HINT: No operator matches the given name and argument type(s). You might
need to add explicit type casts.
Do you know if there is a way for Maserver to manage a daterange field (or a
start_date AND end_date) in a wms-t request?
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
More information about the MapServer-users
