[mapserver-users] Display of an RGB file
Radov, Asen (GSFC-619.0)[UNIVERSITY OF MARYLAND]
asen.s.radov at nasa.gov
Tue Apr 14 08:43:40 PDT 2020
Hello,
I am trying to display a RGB file, but with no success.
I was able to successfully display the RGB file in this example: https://demo.mapserver.org/tutorial/example1-5.html
At this point, I think there is an issue with the file, maybe it is missing some geo location information, but I am not sure.
Can someone double check if they can display this file? Any help is appreciated.
Here is a link to it, since attaching It breaks the size limit:
LC8_015030_20190727_rgb.tif<https://drive.google.com/file/d/1giMI5OPLU6SJZUhkK0ZxfySKSMP88G6G/view>
Here is my map file for reference:
MAP
IMAGETYPE PNG
EXTENT -180 -90 180 90
SIZE 256 256
SHAPEPATH "/tis/stream/data"
# The regular expression below will match 1 or more letters followed by
# underscore followed by 1 or more numeric characters
DATAPATTERN "[a-z]+|_|[0-9]+"
IMAGECOLOR 255 255 255
CONFIG "MS_ERRORFILE" "/usr/local/error.log"
DEBUG 5
SymbolSet "symbols/symbols.sym"
OUTPUTFORMAT
NAME "png"
DRIVER "AGG/PNG"
MIMETYPE "image/PNG"
IMAGEMODE RGBA
TRANSPARENT ON
EXTENSION "png"
FORMATOPTION "COMPRESSION=1"
END
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_title" "WMS STREAM Server" ##required
"wms_onlineresource" "http://localhost:8181/cgi-bin/mapserv?" ##required
"wms_srs" "EPSG:4326" ##recommended
"wms_enable_request" "*" ##necessary
END
END # Web
LAYER
NAME "rgb1"
DATA ""
PROCESSING "BANDS=1,2,3"
TYPE RASTER
STATUS ON
DEBUG 5
PROJECTION
"init=epsg:4326"
END
METADATA
wms_title "Tss range 0-1 layer"
wms_srs "epsg:4326"
wms_extent "-180 -90 180 90"
END
END
END
Thank you,
Asen Radov
NASA Goddard Space Flight Center / Code 619
Phone: 301-614-6517
E-mail: asen.s.radov at nasa.gov<mailto:asen.s.radov at nasa.gov>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200414/4ae9bc4c/attachment-0001.html>
