[mapserver-users] GetFeature WFS request with Spatial Filter throws an error
Andrea Aime
andrea.aime at geo-solutions.it
Sun Apr 26 02:10:32 PDT 2020
Hi Fran,
simple XML error in your filter:
<gml:Point<gml:coordinates>
should be:
<gml:Point><gml:coordinates>
This one returns values:
http://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_PPHH_2012/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=MSPF_POLY&Filter=%3CFilter%3E%3CDWithin%3E%3CPropertyName%3EmsGeometry%3C/PropertyName%3E%3Cgml:Point%3E%3Cgml:coordinates%3E158380,4130457%3C/gml:coordinates%3E%3C/gml:Point%3E%3CDistance%20units=%27m%27%3E10000%3C/Distance%3E%3C/DWithin%3E%3C/Filter%3E
Hope this helps
Cheers
Andrea
On Sat, Apr 25, 2020 at 9:55 PM Fran Acuña Parra <fran.ap89 at gmail.com>
wrote:
> Hi everyone,
> I'm new to this list and MapServer and would like some help with an issue
> that I'm facing with MapServer.
> I'm using the following request in order to get the closest feature from a
> layer given some specific coordinates:
> http://www.juntadeandalucia.es/medioambiente/mapwms/REDIAM_PPHH_2012/wfs?&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=MSPF_POLY&Filter=<Filter><DWithin><PropertyName>msGeometry</PropertyName><gml:Point<gml:coordinates>158380,4130457</gml:coordinates></gml:Point><Distance
> units='m'>10000</Distance></DWithin></Filter>
> It returns the following error:
> msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in
> GetFeature :
> But I don't know what could be wrong because the URL is based on the
> documentation example. I don't have control of the MapServer, but I have
> done a GetCapabilities request to the WFS server and it shows some warnings
> in the FeatureType for the layer:
> <FeatureType>
> <Name>MSPF_POLY</Name>
> WARNING: Mandatory metadata '..._title' was missing in this context.
> <Title>MSPF_POLY</Title>
> <SRS>EPSG:25830</SRS>
> <LatLongBoundingBox minx="100314" miny="3.98535e+06" maxx="615158" maxy="4.18983e+06"/>
> WARNING: Required Feature Id attribute (fid) not specified for this feature type. Make sure you set one of wfs_featureid, ows_featureid or gml_featureid metadata.
> </FeatureType>
> The point coordinates are in the same EPSG that the layer and The
> Filter_Capabilites seem to be OK too. So I don't know If I'm missing
> something.
> Thanks in advance.
> Fran Acuña
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit
http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
(LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200426/21485ae6/attachment.html>
