[mapserver-users] mapserver 7.6.2
Steve Lime sdlime at gmail.com
Thu Dec 31 07:40:10 PST 2020
The original error looks like it was related to this:
https://stackoverflow.com/questions/39700537/undefined-reference-to-boost-serialization-functions
I think you do something like this (see
https://stackoverflow.com/questions/25243336/specifying-libraries-for-cmake-to-link-to-from-command-line
  cmake ... CMAKE_C_STANDARD_LIRBARIES="-lboost_serialization"
The new error looks to be related to multiple versions of GDAL installed.
If you search on "AH01215: GDAL: In GDALDestroy - unloading GDAL shared
library" you'll see that error referenced in a couple of forums, including
mapserver-users. Do you have both a package and source-built GDAL? You
might be better off uninstalling the source-built stuff.
--Steve
On Wed, Dec 30, 2020 at 2:13 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Hi Stephane,
> I'm not sure about your last issue.  You could first execute 'sudo
> ldconfig' so your last compiled libs are found, then try a shp2img
> command with your mapfile.
> I have seen cases where there are conflicting library versions used by
> either the GDAL or MapServer dependencies: test this with a 'ldd <lib
> name> command.
> That's not a fun scenario, but, I've been there before ha.
> Sorry maybe others have better advice for this.
> -jeff
> Jeff McKenna
> GatewayGeo: MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-12-30 1:36 p.m., Stephane Poissant wrote:
> > HI Jeff,
> > That was a partial success! Thank you for you recommendation!
> > It compiled successfully by compiling gems and recompiling goal as you
> > suggested.
> > I still have 1 issue.
> > While rendering stuff that use to work on previous version, it no longer
> > works in this lates one.
> > I get AH01215 error in http.
> > AH01215: GDAL: In GDALDestroy - unloading GDAL shared library.:
> > /var/www/html/map/mapserv.cgi, referer: http://utility.sk.com/
> > <http://utility.sk.com/>
> > I am not a developper. It is hard for me to describe where this issue
> > can possibly come from.
> > It does not render on screen the way it should be.
> > I will turn back on perl, have ruby, python and php in the makefile as
> > it could be related….
> > Nevertheless, I would like to thank you for your very quick response and
> > "right on" target answers!
> > SP
> > Stéphane Poissant
> > Portable: 514-793-3506
> > spoissantca at gmail.com <mailto:spoissantca at gmail.com>
> >> On Dec 30, 2020, at 10:14 AM, Jeff McKenna
> >> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> >> wrote:
> >> Also, after you compile GEOS be sure to recompile GDAL ('make clean'
> >> first), then continue on to tackle your MapServer cmake command.
> >> Happy new year to all,
> >> -jeff
> >> Jeff McKenna
> >> http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >> On 2020-12-30 9:56 a.m., Jeff McKenna wrote:
> >>> Hi Stephane,
> >>> Be sure to compile GEOS (3.9.0 is recommended from
> >>> http://download.osgeo.org/geos/geos-3.9.0.tar.bz2 ), and then add
> >>> into your cmake command: -DWITH_GEOS=1
> >>> Wishing you a happy new year,
> >>> -jeff
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201231/d0e6814b/attachment.htm>
More information about the MapServer-users mailing list
