[mapserver-users] Is Mapserver known to play nice with Proj 6.3 ?
Herzmann, Daryl E [AGRON]
akrherz at iastate.edu
Thu Feb 13 11:39:36 PST 2020
Hi Even,
Thanks for efforting the release. Sadly, since I am using the proj provided by python Anaconda/conda-forge, it will take a few days for the dependency log jam to clear so that I can upgrade to that version.
I would like to note that the CPU usage issue was a silly error on my part with a botched apache configuration not running mapserv as FastCGI as I thought :(
I do still have the issue of needing ACCEPT_USE_OF_DEPRECATED_PROJ_API_H to build mapserver in the master branch. I don't need it when doing the same build procedure from the branch-7-4. I am unsure if it is worth pursuing.
The issue of crashes went away for me when I fixed the apache config issue. My ignorant guess is that CGI execing mapserv hundreds of times per second leads to some fun edge cases.
daryl
________________________________________
Sent: Monday, February 10, 2020 4:27 AM
To: Herzmann, Daryl E [AGRON]
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Is Mapserver known to play nice with Proj 6.3 ?
> 4) new proj 6.3.1 release
> Thank you for prioritizing that! I will certainly give it a spin and report
> back my findings.
PROJ 6.3.1 release candidate announced:
https://lists.osgeo.org/pipermail/proj/2020-February/009360.html
Even
http://www.spatialys.com
More information about the MapServer-users
