[mapserver-users] cgi-error: End of script output before headers mapserv
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jan 22 07:43:16 PST 2020
and you removed all "WARNING" messages from your GetCapabilities response?
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-01-22 11:28 a.m., Johannes Paul wrote:
> Thanks for your help.
> 1. the mapserv cgi command line gave me a proper png (./mapserv -nh
> "QUERY_STRING=map=/var/www/html/osm-transp-en-default.map&mode=map" >
> /tmp/test.png)
> 2. i turned on CPL_DEBUG in my mapfile but it doesn't help
> 3. i ran : shp2img -m /var/www/html/osm-transp-en-default.map -o
> /tmp/test.png -all_debug 5 -e -9.1433 38.7460 -9.1406 38.7487 &>
> /tmp/shp2img_log.txt
> and it looks fine to me...
> On Wed, 22 Jan 2020 at 15:28, Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     The more tests the better :)
>     -jeff
>     On 2020-01-22 10:21 a.m., Jörg Thomsen (WhereGroup) wrote:
>      > Hello Jeff,
>      > is shp2img exactly the same as mapserv? (My thought was to use
>     the same
>      > executable the webserver calls)
>      > Jo,
>      > did you get a proper result (image) from your command line
>     request? the
>      > 'error'-messages look quite OK.
>      > Jörg
>      > Am 22.01.20 um 15:12 schrieb Jeff McKenna:
>      >> Hi Jo,
>      >> Are you passing the problem extents to the shp2img utility?
>     Such as:
>      >>    shp2img -m osm-transp-en-default.map -e -9.1433 38.7460 -9.1406
>      >> 38.7487 -o ttt.png -all_debug 5
>      >> If that doesn't help, then I would start from the beginning:
>     execute a
>      >> GetCapabilities request and make sure you remove all "WARNING"
>     messages.
>      >> -jeff
>      > Viele Grüße,
>      > Jörg Thomsen
More information about the MapServer-users mailing list
