[mapserver-users] cgi-error: End of script output before headers mapserv
Johannes Paul
johannespaul92 at gmail.com
Wed Jan 22 08:16:37 PST 2020
Yes i do have a working url having 5 digits coordinates
Jo
Le mer. 22 janv. 2020 à 17:06, Jörg Thomsen (WhereGroup) <
joerg.thomsen at wheregroup.com> a écrit :
> I still have no idea, but a question:
> Do you see any pattern in working vs. not working bboxes? In your
> example it workes wirth 4-digit coordinates and does not with 5-digit
> coordinates.
> Does ist never work with 5 digits?
> Jörg
> Am 22.01.20 um 16:51 schrieb Johannes Paul:
> > Yes no warnings in my GetCap...
> > Le mer. 22 janv. 2020 à 16:43, Jeff McKenna
> > <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>> a
> > écrit :
> > and you removed all "WARNING" messages from your GetCapabilities
> > response?
> > -jeff
> > Jeff McKenna
> > MapServer Consulting and Training Services
> > https://gatewaygeomatics.com/
> > On 2020-01-22 11:28 a.m., Johannes Paul wrote:
> > > Thanks for your help.
> > > 1. the mapserv cgi command line gave me a proper png (./mapserv -nh
> "QUERY_STRING=map=/var/www/html/osm-transp-en-default.map&mode=map" >
> > > /tmp/test.png)
> > > 2. i turned on CPL_DEBUG in my mapfile but it doesn't help
> > > 3. i ran : shp2img -m /var/www/html/osm-transp-en-default.map -o
> > > /tmp/test.png -all_debug 5 -e -9.1433 38.7460 -9.1406 38.7487 &>
> > > /tmp/shp2img_log.txt
> > > and it looks fine to me...
> > > On Wed, 22 Jan 2020 at 15:28, Jeff McKenna
> > <mailto:jmckenna at gatewaygeomatics.com>>>
> > > wrote:
> > > The more tests the better :)
> > > -jeff
> > > On 2020-01-22 10:21 a.m., Jörg Thomsen (WhereGroup) wrote:
> > > > Hello Jeff,
> > > > is shp2img exactly the same as mapserv? (My thought was to
> use
> > > the same
> > > > executable the webserver calls)
> > > > Jo,
> > > > did you get a proper result (image) from your command line
> > > request? the
> > > > 'error'-messages look quite OK.
> > > > Jörg
> > > > Am 22.01.20 um 15:12 schrieb Jeff McKenna:
> > > >> Hi Jo,
> > > >> Are you passing the problem extents to the shp2img utility?
> > > Such as:
> > > >> shp2img -m osm-transp-en-default.map -e -9.1433 38.7460
> > -9.1406
> > > >> 38.7487 -o ttt.png -all_debug 5
> > > >> If that doesn't help, then I would start from the
> beginning:
> > > execute a
> > > >> GetCapabilities request and make sure you remove all
> "WARNING"
> > > messages.
> > > >> -jeff
> > > > Viele Grüße,
> > > > Jörg Thomsen
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org <mailto:
> mapserver-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Qualifizierte Open-Source-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Fon: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200122/7a86428a/attachment-0001.html>
