[mapserver-users] QGIS / Mapserver WFS filter (bbox/envelope) interoperability issue
Even Rouault
even.rouault at spatialys.com
Fri Jun 5 07:38:52 PDT 2020
On vendredi 5 juin 2020 15:09:22 CEST Even Rouault wrote:
> > So my question: is a newer version of UMN (7.2, 7.4, 7.6) perhaps the
> > "Envelope" style syntax in the WFS filter that QGIS Desktop is sending or
> > should we better try to add a new "bbox" method to the WFS Client of QGIS
> > Desktop? I quickly browsed through the UMN Mapserver changelogs but didn't
> > see any obvious improvement around "Envelope" support in filters.
> Hi Andreas,
> this is quite unfortunate MapServer doesn't support gml:Envelope as a
> geometry in the "Intersects" request, whereas we support it inside a <BBOX>
> filter. The optimistic in me says that shouldn't be too hard to fix.
Was indeed simple to fix:
https://github.com/mapserver/mapserver/pull/6091
On QGIS client side, you may try with WFS 1.0. I don't think QGIS will emit a gml:Envelope
then
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200605/0b343f1e/attachment.htm>
More information about the MapServer-users
