[mapserver-users] SSL curl error when hitting HTTP WMS
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Tue Jun 9 03:55:47 PDT 2020
The service indeed seems to redirect into https address.
GDAL has an "unsafeSSL" option but I believe that Mapserver does not http://osgeo-org.1560.x6.nabble.com/https-url-with-MapServer-as-WMS-client-td5332403.html.
Perhaps you could bypass the certificate check by setting a general curl insecure option as in https://www.cyberciti.biz/faq/how-to-curl-ignore-ssl-certificate-warnings-command-option/. However, it feels rather risky to do it at that level.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Jeff McKenna
Lähetetty: tiistai 9. kesäkuuta 2020 13.10
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] SSL curl error when hitting HTTP WMS
The WMS service that you mention redirects all requests to HTTPS:
https://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?
-jeff
Jeff McKenna
MapServer Consulting and Training Services co-founder of FOSS4G http://gatewaygeo.com/
On 2020-06-09 2:46 a.m., John Huotari wrote:
> I’m attempting to hit a WMS using HTTP, not HTTPS, but I run into the
> following SSL error
> HTTP: request failed with curl error code 60 (SSL certificate problem:
> unable to get local issuer certificate)
> I can get around this error by downloading a CA bundle file and setting
> the CURL_CA_BUNDLE environment variable to point to it, but why is a CA
> bundle file necessary when not even using SSL (hitting a WMS using HTTP,
> not HTTPS)? Does anyone know a workaround that wouldn’t require
> deploying a CA bundle file to my servers and setting an environment
> variable to point to it?
> I’m currently using the stable release of MSVC 2017 x64 package
> downloaded from GISInternals - http://www.gisinternals.com/release.php
> A sample mapfile looks like this
> MAP
> NAME USA1
> STATUS ON
> IMAGETYPE PNG8
> RESOLUTION 72
> IMAGECOLOR 255 255 255
> UNITS METERS
> PROJECTION "proj=lcc" "lat_1=20" "lat_2=60" "lat_0=40"
> "lon_0=-112.52116185" "x_0=0" "y_0=0" "ellps=GRS80" "units=m"
> "datum=NAD83" END
> SIZE 1500 1500
> EXTENT -45292.7219576058 780481.616003812 45290.5126012127
> 871065.05991903
> LAYER
> NAME "WMS_DRG"
> TYPE RASTER
> STATUS ON
> PROJECTION "proj=longlat" "ellps=GRS80" "datum=NAD83" "no_defs" END
> CONNECTION
> "http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "0"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> END
> END
> END
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
