[mapserver-users] PostGIS query problem
Seth G
sethg at geographika.co.uk
Thu Jun 25 13:20:50 PDT 2020
What client are you using?
How long does the query take to complete?
It is likely the client stops waiting for a response.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, Jun 25, 2020, at 10:16 PM, Fernando Martins Pimenta wrote:
> Hi,
> I am using the query below to return a hydrograph of a region (using POSTGIS). This query works perfectly when I use it in pgadmin. With the mapserver, the connection with the client is lost. It records a query that shows no errors in SQL, just shows that the connection has lost. Why is that?
> DATA "geom FROM (
> SELECT
> hidro.fid, hidro.name, ST_Intersection(gcc.geom, hidro.geom) AS geom
> FROM
> vector.hidrography AS hidro,
> vector.gcc AS gcc
> WHERE ST_Intersects(gcc.geom, hidro.geom) AND gcc.name = 'GRANDE'
> ) as subquery USING UNIQUE fid USING SRID=4326"
> Thanks in advance
> *Fernando Martins Pimenta <http://lattes.cnpq.br/0646984654461300>*
> Graduando em Engenharia de Agrimensura e Cartográfica - UFV
> Bacharel em Engenharia de Biossistemas - UFSJ
> www.biosfera.dea.ufv.br
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200625/af1484e5/attachment.htm>
More information about the MapServer-users
