[mapserver-users] SSL curl error when hitting HTTP WMS
John Huotari
John.Huotari at RCIS.com
Mon Jun 8 22:46:13 PDT 2020
I'm attempting to hit a WMS using HTTP, not HTTPS, but I run into the following SSL error
HTTP: request failed with curl error code 60 (SSL certificate problem: unable to get local issuer certificate)
I can get around this error by downloading a CA bundle file and setting the CURL_CA_BUNDLE environment variable to point to it, but why is a CA bundle file necessary when not even using SSL (hitting a WMS using HTTP, not HTTPS)? Does anyone know a workaround that wouldn't require deploying a CA bundle file to my servers and setting an environment variable to point to it?
I'm currently using the stable release of MSVC 2017 x64 package downloaded from GISInternals - http://www.gisinternals.com/release.php
A sample mapfile looks like this
MAP
NAME USA1
STATUS ON
IMAGETYPE PNG8
RESOLUTION 72
IMAGECOLOR 255 255 255
UNITS METERS
PROJECTION "proj=lcc" "lat_1=20" "lat_2=60" "lat_0=40" "lon_0=-112.52116185" "x_0=0" "y_0=0" "ellps=GRS80" "units=m" "datum=NAD83" END
SIZE 1500 1500
EXTENT -45292.7219576058 780481.616003812 45290.5126012127 871065.05991903
LAYER
NAME "WMS_DRG"
TYPE RASTER
STATUS ON
PROJECTION "proj=longlat" "ellps=GRS80" "datum=NAD83" "no_defs" END
CONNECTION "http://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "0"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
END
END
END
******************* PLEASE NOTE *******************
This message, along with any attachments, is for the designated recipient(s) only and may contain privileged, proprietary, or otherwise confidential information. If this message has reached you in error, kindly destroy it without review and notify the sender immediately. Any other use of such misdirected e-mail by you is prohibited. Where allowed by local law, electronic communications with Zurich and its affiliates, including e-mail and instant messaging (including content), may be scanned for the purposes of information security and assessment of internal compliance with company policy.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200609/55bbde9a/attachment.html>
