[mapserver-users] Sliver when displaying 0°-360° NetCDF data in EPSG:3857
Rousseau Lambert2, Louis-Philippe (EC)
louis-philippe.rousseaulambert2 at canada.ca
Fri Jun 26 06:00:31 PDT 2020
This issue is related to:
* https://github.com/mapserver/mapserver/commit/722716c49de2399f54b275ab31437f0e8c92cd63
* https://github.com/mapserver/mapserver/commit/4c2aeb4bbd229723d8ea67c337cf02350575b2ae
The issue is that when I try to visualize (via WMS) a layer with a NetCDF data file with longitude from 0° to 360° in EPSG:3857, there is a sliver around longitude 0° where no data is displayed.
We already had that issue with the same files using EPSG:4326 and it's been fixed in MapServer (see merge request above).
Here is where you can find example files: https://dd.weather.gc.ca/model_giops/netcdf/lat_lon/2d/00/003/CMC_giops_votemper_depth_0.5_latlon0.2x0.2_3h-mean_{yyyymmdd}00_P003.nc
We are testing using: MapServer version 7.4.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=POINT_Z_M INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Here is a minimal mapfile to reproduce:
MAP
NAME ""
IMAGETYPE PNG
EXTENT -180 -90 180 90
MAXSIZE 4096
SIZE 500 300
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:4326"
END
TRANSPARENT ON
DEBUG 5
WEB
METADATA
"ows_extent" "-180 -90 180 90"
"wms_getmap_formatlist" "image/png,image/jpeg"
"wms_timeformat" "YYYY-MM-DDTHH:MM:SSZ"
"wms_getfeatureinfo_formatlist" "text/plain"
"ows_enable_request" "*"
"ows_abstract" ""
"ows_srs" "EPSG:4326 EPSG:3857"
"ows_title" ""
END
END
LAYER
NAME "TEST"
DEBUG 5
TYPE RASTER
PROCESSING "GDAL_NETCDF_BOTTOMUP=YES"
TOLERANCE 15
TEMPLATE "ttt.html"
PROJECTION
"proj=longlat"
"a=6371229"
"b=6371229"
"lon_wrap=180"
"no_defs"
END
DATA ''
METADATA
"ows_title" ""
"ows_abstract" ""
"ows_extent" "-180 -80.1 180 89.9"
"ows_geomtype" "Geometry"
END
CLASS
NAME ""
STYLE
COLORRANGE 0 0 127 127 0 0
DATARANGE 200.00 400
END
END
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200626/9843147d/attachment.html>
