[mapserver-users] Sliver when displaying 0°-360° NetCDF data in EPSG:3857
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jun 26 11:04:47 PDT 2020
the mapfile is visible at https://gatewaygeomatics.com/dl/netcdf-test.map
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-06-26 2:56 p.m., Jeff McKenna wrote:
> Hi Louis-Philippe,
> With much kind respect, the test case that you provided was not very
> simple, so I had to spend much effort to create a tiny test case, that
> contains one of your NetCDF files, and a small mapfile that simply
> reprojects the file into EPSG:3857 (without WMS etc.). The small test
> case contains a single shp2img command to replicate the issue (in a file
> 'commands.txt') which you can download at
> https://gatewaygeomatics.com/dl/netcdf-2020-06-26.zip
> The issue that you report, of a sliver (no data) in the map when
> reprojecting to 3857, is visible in the resulting map images in the live
> demo at:
> https://demo.gatewaygeomatics.com/cgi-bin/mapserv?MAP=/home/apps/netcdf/2020-06-26/netcdf-test.map&MODE=browse&TEMPLATE=openlayers&LAYERS=all
> (this server is running MapServer-master)
> This should be filed as a new ticket at
> https://github.com/mapserver/mapserver/issues and point to this test
> zipfile.
> Have a nice weekend,
> -jeff
