[mapserver-users] Problem with Python MapScript queryByRect
Just van den Broecke
justb4 at gmail.com
Sun Jun 28 03:20:21 PDT 2020
Solved, there was some kind of mismatch probably with library versions
from multi-stage Docker builds/copies.
Made a new Dockerfile from buster-slim with standard Mapserver (7.2.2 )
and Lighttpd and apart from some new MapScript syntax, all works!
The Dockerfile is nice and small (296MB uncompressed), works
out-of-the-box with FastCGI/WSGI, albeit somewhat older MS version:
https://github.com/justb4/mapglow/blob/master/Dockerfile
Best,
Just
On 27-06-20 15:08, Just van den Broecke wrote:
> I got somewhat further: it appears I get a SEGFAULT when calling any
> MapScript query() method. This is also what FastCGI receives (signal 11).
> For example, bash-ing into the Docker Container and execute MapScript
> Python:
> $ python
> Python 2.7.16 (default, Oct 10 2019, 22:02:15)
> [GCC 8.3.0] on linux2
> >>> import mapscript
> >>> map = mapscript.mapObj('/app1/config/mapserver/app1.map')
> >>> layer = map.getLayerByName('nlpubs')
> >>> layer.name
> 'nlpubs'
> >>> len(layer.metadata)
> 0
> >>> res = layer.queryByAttributes(map, 'Name', 'Lef',
> mapscript.MS_MULTIPLE)
> Segmentation fault
> But getting number of Features is ok:
> >>> layer.getNumFeatures()
> GNM: GNMRegisterAllInternal
> GNM: RegisterGNMFile
> GNM: RegisterGNMdatabase
> GDAL: GDALOpen(/app1/data/pubs, this=0x557ace611b90) succeeds as ESRI
> Shapefile.
> Shape: DBF Codepage = LDID/87 for /app1/data/pubs/osm-nl-pub.shp
> Shape: Treating as encoding 'ISO-8859-1'.
> GDAL: GDALClose(/app1/data/pubs, this=0x557ace611b90)
> 2864
> The LAYER def is
> LAYER
> NAME nlpubs
> STATUS default
> TYPE POINT
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wfs_title" "NL Pubs from OSM POIs"
> "wfs_version" "1.1.0"
> "wfs_extent" "4 50 6 54"
> "wfs_bbox_extended" "true"
> "wfs_enable_request" "*"
> "wfs_srs" "epsg:4326 epsg:3857 epsg:900913"
> "wfs_include_items" "all"
> "gml_include_items" "all"
> "gml_geometries" "geom"
> "wms_title" "NL Pubs from OSM POIs"
> "wms_srs" "epsg:4326 epsg:3857 epsg:900913"
> "wms_extent" "4 50 6 54"
> "wms_feature_info_mime_type" "text/xml"
> "mapglow_feat_density" "0.002"
> END
> CONNECTIONTYPE OGR
> CONNECTION "/app1/data/pubs"
> DATA "osm-nl-pub"
> TEMPLATE "/app1/config/mapserver/template.html"
> CLASS
> NAME "osm-nl-pub"
> STYLE
> COLOR 0 102 204
> SYMBOL "circle"
> SIZE 10
> END
> END
> END
> Data is a shapefile, but GeoJSON also fails. Also strange that
> layer.metadata is empty. Like said when I delegate any incoming OWS req
> to map.OWSDispatch() I get proper results for all WMS requests, in
> particular GetMap with styled output.
> The base Dockerfile used is at:
> https://github.com/PDOK/mapserver-docker/blob/master/Dockerfile from
> which I derived my Dockerfile:
> Maybe there is some mismatch in lib versions?
> Again thanks. Best,
> On 26-06-20 17:55, Just van den Broecke wrote:
>> Hi,
>> I am reviving a Python 2 MapServer MapScript app that used to work 7
>> years ago (and still is in old deployment) but stuck in some MapScript
>> calls that fail but also throw no Exceptions.
>> Purpose of the app "MapGlow" [1] is to generate a WMS-heatmap
>> triggered by specific STYLE parameters. When no heatmap STYLE is
>> requested requests are delegated to map_file.OWSDispatch() etc. The
>> latter works fine so the overall setup/stack/mapfile is working. Using
>> MS 7.6.0 in Docker (compose) with Lighttp, FastCGI, WSGI, flup.
>> It is only when layerObj.queryByRect() is called, a HTTP 500 is
>> returned after a FastCGI hard error, no means to catch an Exception.
>> The passed MapFile and Rect objects seem ok. Also I noticed that
>> layerObj.metadata had 0 items. I can see that I have proper SWIG
>> objects like
>> <mapscript.layerObj; proxy of <Swig Object of type 'layerObj *' at
>> 0x7fded06b1de0> >
>> If only I could get a hint, a MapFile setting, maybe some log output
>> or debug flag I can set? The WIP is on GH, I can point at the failing
>> line [2] but the code is
>> quite involved (mind, my first Python 7-9 years ago):
>> [1] https://github.com/justb4/mapglow
>> [2]
>> https://github.com/justb4/mapglow/blob/master/app1/wms/mapglow_ms.py#L249
>> Thanks for any help,
>> The Netherlands
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
