[mapserver-users] Mapserver 6.4 does not draw dense line segments at lower zoom levels. Why?
Steve Lime
sdlime at gmail.com
Mon Mar 2 16:26:03 PST 2020
Hi! My guess is your v.5 style is being interpreted differently in v.6. For
example, what’s the purpose of the ANGLE 360? There were some big changes
between versions 5 and 6. For example you don’t have to use a circular
brush to draw a thick line. You should be able to do something much simpler
like:
STYLE
COLOR 0 0 255
WIDTH 2
END
—Steve
On Mon, Mar 2, 2020 at 4:48 PM Ei Fujioka <efujioka at duke.edu> wrote:
> Hello all,
> I'm upgrading a web site that I have been developing for many years. The
> web site uses Mapserver & Mapscript along with PHP. Mapserver layers are
> drawn on top of Google Maps using Javascript.
> What I'm struggling to figure out is that a line layer is not drawn at
> lower zoom levels with Mapserver & Mapscript 6.4 and PHP 5.4.16. When
> zooming in, the lines will start getting drawn but still not fully.
> The same layer was drawn at any zoom levels without any problem under
> Mapserver 5.2 and PHP 5.2.6.
> Are there any mapfile settings (new to Mapserver 6.4 or changed from
> Mapserver 5.2) that limit the number of line segments to be drawn at
> unit cell or affects how the lines are drawn at differently zoom levels?
> Are there any limits in Mapscript/PHP regarding data size to fetch or
> draw? The line data of the layer is stored in a PostgreSQL table which
> has a lot of records (~270,000 line segments). If the line layer does
> not have such a large number of records (e.g. ~10,000), it draws fine.
> Please take a look at an image (screenshots) that shows how the lines
> are drawn differently between Mapserver 5.2 and Mapserver 6.4:
> http://seamap.env.duke.edu/images/mapserver6_4_not_draw_lines.png
> The new web site is not publicly available yet, so I can't let you
> explore but the existing web site that draws the example line layer fine
> can be accessed at
> http://seamap.env.duke.edu/dataset/2001
> # Please turn on "Survey tracks" in the Layer selection.
> The snippet of the mapfile is below.
> Thanks for your help in advance!
> Ei Fujioka
> Duke University
> === Mapfile ===
> MAP
> EXTENT -20001364 -15000982 20001253 15000982
> IMAGETYPE "PNG"
> NAME "OBIS-SEAMAP_OGC_SERVICES"
> SIZE 256 256
> STATUS ON
> TRANSPARENT TRUE
> UNITS METERS
> OUTPUTFORMAT
> NAME "PNG"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE RGBA
> TRANSPARENT TRUE
> END # OUTPUTFORMAT
> PROJECTION
> "init=epsg:3857"
> END # PROJECTION
> SYMBOL
> NAME "solid_line"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED true
> END
> WEB
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "wms_srs" "EPSG:3857 EPSG:4326"
> "ows_enable_request" "*"
> "wms_title" "Online Mapper"
> END # METADATA
> END # WEB
> LAYER
> CLASSITEM "classitem_dataset"
> CONNECTION "user=xxx password=xxx dbname=xxx host=xxx"
> CONNECTIONTYPE POSTGIS
> DATA "geom from (SELECT ..., as classitem_dataset, 'solid_line' as
> symbol FROM z_tracks WHERE ...) AS foo USING UNIQUE oid USING SRID=4326"
> METADATA
> "wms_legend_graphic" "true"
> "gml_featureid" "oid"
> "title" "Survey tracklines"
> "gml_include_items" "all"
> "wms_title" "Survey tracklines"
> END # METADATA
> NAME "survey_tracks"
> PROJECTION
> "init=epsg:4326"
> END # PROJECTION
> STATUS OFF
> TILEITEM "location"
> TOLERANCE 1
> TYPE LINE
> UNITS METERS
> CLASS
> NAME "class_0"
> EXPRESSION "0_ON"
> STYLE
> ANGLE 360
> COLOR 255 0 0
> OUTLINECOLOR 255 0 0
> SIZE 2
> SYMBOL [symbol]
> END # STYLE
> END # CLASS
> # In total 60 CLASS ... END are defined
> END # LAYER
> Ei Fujioka
> Research Scientist
> Nicholas School
> Duke University
> (919) 684-3518
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200302/f645c69b/attachment.htm>
More information about the MapServer-users
