[mapserver-users] MapCache Larger tiles, reduce number of files
Jean-Philippe Chenel jp.chenel at live.ca
Tue Mar 10 13:33:30 PDT 2020
Dear Steve,
Thanks for your help and here is the solution.
The grid in mapcache.xml was good (same resolution as the default with 256x256, the only difference is the size of the tile)
<grid name="GoogleMaps512">
<extent>-20037508.3427892480 -20037508.3427892480 20037508.3427892480 20037508.3427892480</extent>
<srs>EPSG:3857</srs>
<units>m</units>
<size>512 512</size>
<resolutions>156543.0339280410 78271.51696402048 39135.75848201023 19567.87924100512 9783.939620502561 4891.969810251280 2445.984905125640 1222.992452562820 611.4962262814100 305.7481131407048 152.8740565703525 76.43702828517624 38.21851414258813 19.10925707129406 9.554628535647032 4.777314267823516 2.388657133911758 1.194328566955879 0.5971642834779395</resolutions>
</grid>
The problem was in the OL configuration, when you said that the tilesize is something else, I suppose that the resolution also changes without to do anything. The solution was to make another tilegrid configuration like that and to bind it to the source.
var projExtent = ol.proj.get('EPSG:3857').getExtent();
var startResolution = ol.extent.getWidth(projExtent) / 256;
var resolutions = new Array(22);
var tileSize = 512;
var urlTemplate = '/GoogleMaps512/{z}/{x}/{y}.png';
for (var i = 0, ii = resolutions.length; i < ii; ++i) {
  resolutions[i] = startResolution / Math.pow(2, i);
var tileGrid = new ol.tilegrid.TileGrid({
  extent: [-20037508.3427892480, -20037508.3427892480, 20037508.3427892480, 20037508.3427892480],
  resolutions: resolutions,
  tileSize: [512, 512]
var source1 = new ol.source.XYZ({
url: urlTemplate,
tileSize: tileSize,
    tileGrid: tileGrid
With best regards,
De : Stephen Woodbridge <stephenwoodbridge37 at gmail.com>
Envoyé : 9 mars 2020 16:46
À : Jean-Philippe Chenel <jp.chenel at live.ca>; mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Objet : Re: [mapserver-users] MapCache Larger tiles, reduce number of files
Are you sure you have the set the tile size correctly in OpenLayers?
Because if OL is requesting tiles that you don't have it sounds like
that is the reason.
And if you do load tile and there is a miss-match, then I would expect
the resolution of be off.
Here are a few links that might help:
https://openlayers.org/en/latest/examples/wms-custom-tilegrid-512x256.html
https://openlayers.org/en/latest/apidoc/module-ol_tilegrid_TileGrid-TileGrid.html
https://stackoverflow.com/questions/57072232/how-to-change-tilesize-in-xyz-tilelayer-from-default256-256-to-something-e
On 3/9/2020 3:21 PM, Jean-Philippe Chenel wrote:
> Steve,
> It is what I supposed, but when I've generated the tiles 512x512 using
> the default resolution GoogleMapCompatible, with the cache template
> {z}/{x}/{y}.{ext} and loaded it in OpenLayers using ol.source.XYZ,
> I've noticied that the x tile being tried to load was not in the good
> range.
> z/x/-y.png
> Tiles generated:
> .../8/37 and 38/64 and 65.png
> Tiles loaded by OpenLayers (with error 404):
> .../8/73 to 77/130 and 131.png
> Thanks,
> *De :* mapserver-users <mapserver-users-bounces at lists.osgeo.org> de la
> part de Stephen Woodbridge <stephenwoodbridge37 at gmail.com>
> *Envoyé :* 9 mars 2020 14:56
> *À :* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Objet :* Re: [mapserver-users] MapCache Larger tiles, reduce number
> of files
> Jean-Philippe,
> I don't think it works like that. Resolution is determined by zoom
> factor so you generate  metatile at that resolution then you chop that
> metatile in tiles of whatever size you specify. So resolution is
> controled by zoom not tile size.
> -Steve W
> On 3/9/2020 2:45 PM, Jean-Philippe Chenel wrote:
> > Hi,
> > With MapCache, I want to generate the tiles that will be copied to a
> > mobile device, on a viewer created with OpenLayers.
> > When generating a large extent, with multiple levels of zoom, the
> > files count is really big, so I want to reduce the number of files by
> > increasing the tile size. I've made a test with tiles 512x512, but
> > I've realized that the resolution must be changed when changing tiles
> > size. So, the tiles are bigger, but changing the resolution make
> > generating the same number of files.
> > I'm open for workaround and other tricks.
> > mapcache.xml
> > <metadata>
> > <title>GoogleMaps512</title>
> > </metadata>
> > <srsalias>EPSG:900913</srsalias>
> > <units>m</units>
> > </grid>
> > <cache name="tmpl_xyz" type="disk" layout="template">
> <template>/data/mapcache/tiles/{tileset}/{grid}/{z}/{x}/{y}.{ext}</template>
> > </cache>
> > <tileset name="OpenStreetMap">
> > <source>vmap0</source>
> > <cache>tmpl_xyz</cache>
> > <grid>GoogleMaps512</grid>
> > <format>PNG</format>
> > </tileset>
> > With best regards,
> > mapserver-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200310/f9e89701/attachment.htm>
More information about the MapServer-users mailing list
