[mapserver-users] mapserver 7.4.3 on centos 8 and gdal 3.0.4
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Mar 11 04:31:14 PDT 2020
Glad you solved it.
Related tip: GEOS 3.8.1 is now available.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-03-05 6:03 p.m., Domenico Febbo wrote:
> Dears
> issue was solved as you suggested arranging right version of GEOS, GDAL
> and PROJ
> see my working cmake command
> cmake
> -DCMAKE_PREFIX_PATH="/usr/geos38;/usr/proj63;/usr/gdal30;/usr/pgsql-12;/usr/local" -DWITH_CLIENT_WFS=OFF -DWITH_CLIENT_WMS=ON -DWITH_CURL=ON -DWITH_PHP=ON -DWITH_SVGCAIRO=OFF -DWITH_PROTOBUFC=OFF -DWITH_CAIRO=OFF -DWITH_FRIBIDI=OFF -DWITH_HARFBUZZ=OFF -DWITH_GEOS=ON ../
> Regards,
> Date: Thu, 05 Mar 2020 18:23:11 +0100
> From: Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>>
> To: mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> Subject: Re: [mapserver-users] mapserver 7.4.3 on centos 8 and gdal
> 3.0.4
> Message-ID: <5264658.HpSgdfGQFN at even-i700>
> Content-Type: text/plain; charset="us-ascii"
> On jeudi 5 mars 2020 13:11:59 CET Jeff McKenna wrote:
> > Also, recompile GDAL after you build GEOS 3.8.0, as GDAL >3 requires
> > GEOS. -jeff
> There's no GDAL > 3 for now ;-) But, joke aside, GDAL 3 doesn't change
> requirements regarding GEOS. GEOS is a recommended dependency, but
> not a
> compulsory one. Only PROJ >= 6 is a compulsory dependency for GDAL >= 3
> Even
