[mapserver-users] layer with "truncated" symbols 2
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Mar 27 02:54:38 PDT 2020
Your problem is on the client side. OpenLayers is now requesting tiles with 256x256 pixels. The middle tile has not any point inside its bounding box and therefore no symbols are rendered. Configure OpenLayers to do single tile requests.
http://dev.openlayers.org/examples/single-tile.html
Posts from gis.stackexchange dealing with this common issue with tiling clients:
https://gis.stackexchange.com/questions/198450/need-clarification-on-geoserver-meta-tile
https://gis.stackexchange.com/questions/87116/geoserver-cutting-off-symbols-close-to-tile-edges/87123#87123
https://gis.stackexchange.com/questions/83033/single-tiled-mapserver-wms-to-avoid-labels-and-features-cut-along-tile-borders-a
Duplicated labels is another version of the same issue
https://www.geowebcache.org/docs/current/concepts/metatiles.html
Using some tile cache program like MapProxy, MapCache of GeoWebCache between OpenLayers and WMS is another way to resolve the problem.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Leehan
Lähetetty: perjantai 27. maaliskuuta 2020 11.27
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] layer with "truncated" symbols 2
following your advice, I added quedalle classe :
LAYER
NAME "nombre de cas"
TYPE POINT
PROJECTION
"init=epsg:2154"
END
EXTENT 276838.0988 4584246.823 909596.998 8872270.142
CONNECTIONTYPE POSTGIS
CONNECTION blabla
LABELITEM "nb_cas"
CLASS
EXPRESSION "quedalle"
STYLE
SYMBOL "circle"
SIZE 150
COLOR 0 0 0
END
END
CLASS
STYLE
SYMBOL "cas"
SIZE [ln_nb_cas]
COLOR [couleur]
OPACITY 70
END #fin style
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
FONT "verdana-gras"
TYPE truetype
SIZE 8
END
END #fin class
And indeed I am using an attribute for red circle size.
But the result is still the same.
(I can't believe I am the first to experience this issue!) If it can help, here is a snap with the dummy class :
<http://osgeo-org.1560.x6.nabble.com/file/t372757/map.png>
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-User-f4226646.html
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
