[mapserver-users] *NAMESPRO.CA Detected Spam* Re: layer with "truncated" symbols 2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Mar 27 04:52:18 PDT 2020
To help give back to the community (from all the good support you
received), you could take your mapfile layer, issue description, images,
and solution, and document it on the MapServer wiki in the "Tips,
Tricks, Howto" section at https://github.com/mapserver/mapserver/wiki
thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-03-27 8:36 a.m., Leehan wrote:
> Thanks for all these links.
> I read most of them and understood a very few. I tried to find the simplest
> solution for me.
> In OL doc, I noticed a gutter option for ol/source/TileWMS. According to
> this, on Mapserver side, there was a parameter to adjust :
> tile_map_edge_buffer, I never found where to modify it !
> So as a start, I only added a "gutter: 50" on my js file. As far as I
> understand : a buffer is created around red circle so symbols are "cut" but
> farther so they appear entirely. It was enough.
> <http://osgeo-org.1560.x6.nabble.com/file/t372757/map.png>
