[mapserver-users] Java MapScript on Tomcat servlet does not free GeoTIFF file handles
Even Rouault
even.rouault at spatialys.com
Fri May 22 06:27:17 PDT 2020
> Problem 1:
> Tomcat-process does not free GeoTIFF file-handles per (pooling) thread.
> With "Resource Monitor" of Windows, it is confirmed that Tomcat8.exe is
> holding file-handles of "foobar.tif".
> MapFile:
> MAP
> LAYER
> TYPE RASTER
> STATUS ON
> DATA "foobar.tif"
> END
> END
You probably need to add
PROCESSING "CLOSE_CONNECTION=ALWAYS"
in your LAYER definition
By default, datasets of raster layers are kept open until MapServer is terminated.
CLOSE_CONNECTION is described in https://mapserver.org/mapfile/layer.html, but as far as I
can see, not explicit about this particular behaviour of raster layers where the default is
DEFER.
The "documentation" is at:
https://github.com/mapserver/mapserver/blob/
c4006da79bc59e30478d9e2354070ffb9dcbc614/mapraster.c#L675
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200522/14703a16/attachment.htm>
More information about the MapServer-users
