[mapserver-users] Version 7.7 & proj.db
aimdev at mail.com
aimdev at mail.com
Tue Nov 24 03:58:32 PST 2020
Built mapserver 7.7? from the master on github, using Debian Bullseye & Postgresql 13 with PostGis v 3..
root at bullseye-alpha:/home/osm/var/www/gis# mapserv -v
MapServer version 7.7-dev OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
While scanning the debug.log, noticed
debugFile.log:[Mon Nov 23 16:24:25 2020].912914 PROJ: Debug: proj_as_proj_string: Cannot find proj.db
debugFile.log:[Mon Nov 23 16:24:25 2020].913854 PROJ: Debug: proj_create_operation_factory_context: Cannot find proj.db
The map presents ok as far as I can tell.
Is this cause for concern as a Google search shows a number of hits with various software having a similar message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201124/62e53039/attachment.htm>
More information about the MapServer-users
