[mapserver-users] Version 7.7 & proj.db
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Nov 24 04:18:37 PST 2020
On 2020-11-24 8:12 a.m., Jeff McKenna wrote:
> Master now requires PROJ 7 (and PROJ now requires SQLite, LibTIFF,
> Curl).  The PROJ build process should generate 'proj.db' inside /data,
> and 'make install' should place that file in something like
> /usr/local/share/proj/proj.db
> Make sure that GDAL and MapServer are built with PROJ 7 (7.2.0 is
> recommended).
> -jeff
Be careful also that if you have compiled the GeoTIFF library yourself,
that it also requires PROJ (and therefore PROJ 7).  I've had to
recompile that on many client systems.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-users mailing list
