[mapserver-users] Mapfile WMS configuration fail
Lars Schylberg
lars.schylberg at blixtmail.se
Fri Oct 2 10:08:26 PDT 2020
This usually the order I test mapserver configurations.
1) Test your mapfile with shp2img
https://www.mapserver.org/utilities/shp2img.html
2) Test your WMS config with the built in open layers viewer:
https://mapserver.org/cgi/openlayers.html
3) Test with QGIS
If you really want test the mapserver syntax, install and use:
https://mappyfile.readthedocs.io/en/latest/ and use the validate
command on the command line.
Good luck !
/Lars Schylberg
Den 2020-10-02 kl. 18:54, skrev BRIAN STIFFENN LUNA BOLIVAR:
> Hello everyone, good day. I have a problem when making the wms request
> through QGIS, where when loading the layer I get the following error:
> "connection rejected".
> 1. How can I solve it?
> 2. In Mapbender, I have an error when connecting the WMS, because the
> error that appears is the following: Error in the source mapping:
> Error: request failed with status 404; can it be because of the
> problem with the configuration of my mapfile?
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201002/0f0c9dac/attachment.htm>
More information about the MapServer-users
