[mapserver-users] Mapserver 7.6.1 - PHP 7 Swig - Kml output issue
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 15 05:41:14 PDT 2020
Hi Bruno,
What happens if you call that mapfile at the commandline with shp2img
(and pass the "i" switch with your format name)? such as:
shp2img -m mymap.map -o ttt.png -i kml -all_debug 5
You can also then try png output:
shp2img -m mymap.map -o ttt.png -i png -all_debug 5
Does it generate a valid map image?
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-10-15 9:14 a.m., Bruno Domenget wrote:
> Hi all !
> On a brand new debian server with Mapserver 7.6.1 / SWIG PHP Mapscript
> (+ GDal 3.13 and Proj 7.1.1) I am encountering a strange issue with KML
> output format. The code and mapfiles I am using were working perfectly
> on an old Mapserver 6.4 / PHP mapscript installation, I just converted
> the PHP functions to the SWIG interface.
> On a simple map file and PHP script the map shows fine, but when I
> select KML as outputformat ( $map->selectOutputFormat('kml'); ) I get
> the following error : *Fatal error: Uncaught Exception: msDrawMap():
> Image handling error. Failed to draw layer named 'Points'. in
> /home/mapserver/public_html/lib/mapscript.php:2637*
> /Stack trace: #0 /home/mapserver/public_html/lib/mapscript.php(2637):
> mapobj_draw() #1
> /home/mapserver/public_html/test/test_points_export.php(15):
> mapObj->draw() #2 {main} thrown in
> /home/mapserver/public_html/lib/mapscript.php on line 2637/
> There is no detail in the logs concerning that error, and I haven’t
> found any suitable solution. *It works if I remove the LABEL entry from
> the layer class, but then there is no label…*
> I tried with several PHP versions (7.1, 7.3, 7.4) and it always gave me
> the same result. Everything else works perfectly, I have no issue with
> Shapefile or Mapinfo output.
> Does anybody know what is going on ?
> Here is an example of mapfile that causes this issue :
> https://pastebin.com/LFxZ1L9T
> And the PHP code :
> https://pastebin.com/Tp30bzf3
> Thanks,
> Bruno
More information about the MapServer-users
