[mapserver-users] Mapserver 7.6.1 - PHP 7 Swig - Kml output issue
Bruno Domenget
bruno.domenget.roch at gmail.com
Thu Oct 15 06:58:34 PDT 2020
Sorry I should have said at first that I already checked that. I have both
KML and LIBKML drivers listed.
And KML output works if I remove the LABEL entry from my mapfile...
Le jeu. 15 oct. 2020 à 09:52, Jeff McKenna <jmckenna at gatewaygeomatics.com>
a écrit :
> Hi Bruno,
> Next test is to test that your local GDAL was built with KML support:
> ogrinfo --formats
> (you should see a 'LIBKML' or 'KML' driver listed there, either one can
> be used for this)
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-10-15 10:48 a.m., Bruno Domenget wrote:
> > Hi Jeff,
> > Thanks for your quick answer !
> > So I tried with shp2img but got the same error with KML output...
> > *msDrawMap(): Image handling error. Failed to draw layer named 'points'.
> > <br>
> > GDAL: In GDALDestroy - unloading GDAL shared library.*
> > Logfile :
> > [Thu Oct 15 15:36:02 2020].174254 msLoadMap(): 0.005s
> > [Thu Oct 15 15:36:02 2020].174344 msDrawMap(): rendering using
> > outputformat named kml (KML).
> > [Thu Oct 15 15:36:02 2020].174348 msDrawMap(): WMS/WFS set-up and query,
> > 0.000s
> > [Thu Oct 15 15:36:02 2020].174369 msINLINELayerOpen: Layer is already
> open!
> > [Thu Oct 15 15:36:02 2020].174564
> > msSaveImage(/home/mapserver/public_html/test/././5f885042_26ab_0.png)
> > total time: 0.000s
> > [Thu Oct 15 15:36:02 2020].174629 msDrawMap(): Image handling error.
> > [Thu Oct 15 15:36:02 2020].174649 msFreeMap(): freeing map at
> > 0x559913f1af60.
> > [Thu Oct 15 15:36:02 2020].174698 freeLayer(): freeing layer at
> > 0x559914207ad0.
> > It works perfectly with PNG output, and with KML output if I remove the
> > LABEL lines from my mapfile.
> > So it is not a Mapscript issue, there is definitely an issue with my
> > Mapserver instance...
> > Bruno
> > Le jeu. 15 oct. 2020 à 08:42, Jeff McKenna
> > <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> a
> > écrit :
> > oops here is the correct command for kml output:
> > shp2img -m mymap.map -o ttt.kml -i kml -all_debug 5
> > (does that generate a valid KML file?)
> > -jeff
> > Jeff McKenna
> > On 2020-10-15 9:41 a.m., Jeff McKenna wrote:
> > > Hi Bruno,
> > > What happens if you call that mapfile at the commandline with
> > shp2img
> > > (and pass the "i" switch with your format name)? such as:
> > > shp2img -m mymap.map -o ttt.png -i kml -all_debug 5
> > > You can also then try png output:
> > > shp2img -m mymap.map -o ttt.png -i png -all_debug 5
> > > Does it generate a valid map image?
> > > -jeff
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org <mailto:
> mapserver-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20201015/8fa94696/attachment.htm>
More information about the MapServer-users
