[mapserver-users] problem with getcapabilities xml generation when layer is using data from postgresql inherited table
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Oct 21 04:31:39 PDT 2020
Hi Dimitri,
For database connections such as PostgreSQL I always manually set the
LAYER metadata "wms_extent" for each layer (the actual bounding box of
that specific table in PostGIS), so that MapServer does not have to
calculate the extents for the GetCapabilities for each layer. (I
believe this is also mentioned as a "WARNING" in the GetCapabilities
response).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-10-21 7:14 a.m., Zmitser Kozhukh wrote:
> Good time of the day, may be it is my misconception, but I used to think
> that generation of GetCapabilities xml doesn’t require checking that the
> data source of the layer is valid and it really has data etc. I was
> thinking that this is just a matter of converting metadata from mapfile
> to xml format by certain rules.
> But it appears, that it is different from what I have been thinking. I
> am having a wms service that reads data from inherited postgresql table
> (table inherits data from many thousands of childs table) and it takes
> infinity to generate getcapabilities xml document:
> https://gis.lesprojekt.cz/cgi-bin/mapserv?map=/home/dima/maps/olu/european_openlandusemap.map&service=WMS&request=GetCapabilities
> With other wms services that use just ordinary tables as data source it
> (this instance of mapserver) works just fine.
> So my questions is : is it possible to change the code of mapserver not
> to check all child tables and instead just generate getcapabilities xml
> from the metadata in mapfile?
> Or may be someone had this issue and found other solution?
> I think in older versions of mapserver (this concrete instance
> is version 7.2.0 ) inherited tables didn’t cause any troubles.
> Sincerely, Dimitri
