[mapserver-users] Use Ground Control Points from GeoTIFF
Jesper Kempe
jesper.kempe at gmail.com
Tue Sep 1 08:26:07 PDT 2020
Hi
I have a GeoTiff file that gdalinfo presents like this:
gdalinfo sat.tif
Driver: GTiff/GeoTIFF
Files: sat.tif
Size is 10474, 10717
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=1, Info=
(0,0) -> (27.5783052509812,65.9184735836942,229.992792810313)
GCP[ 1]: Id=2, Info=
(524,0) -> (27.1416007200269,65.9731480840222,172.994255514815)
GCP[ 2]: Id=3, Info=
(1048,0) -> (26.7005564512604,66.0268770755367,152.994545626454)
GCP[ 3]: Id=4, Info=
(1572,0) -> (26.257537545879,66.0793551447287,131.994995356537)
GCP[ 4]: Id=5, Info=
(2096,0) -> (25.8102107755995,66.1308402121171,163.993212723173)
with 482 GCPs.
The file opens ok in Qgis and is located in the right location.
But I can´t in any way get it to show correctly in Mapserver.
Is this possible to do? Or do I have to gdalwarp the file to a known
projection and set the PROJECTION of the layer?
Thanks
Jesper
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200901/ad4a9630/attachment.htm>
More information about the MapServer-users
