[mapserver-users] Use Ground Control Points from GeoTIFF
Jesper Kempe jesper.kempe at gmail.com
Thu Sep 3 05:17:49 PDT 2020
Hi Jukka
Sorry about that, I forgot that yesterday.
I did a test now and that actually works!
Changing DATA to the vrt-file and setting
PROJECTION
  "init=epsg:3857"
END
creates an image with sat.tif placed correctly!
$ shp2img -m icesat.map -o /data/temp/Jesper/ttt.png -all_debug 5
msLoadMap(): 0.014s
msDrawMap(): rendering using outputformat named png (AGG/PNG).
msDrawRasterLayerLow(sat): entering.
msResampleGDALToMap in effect: cellsize = 4202.211585
msDrawGDAL(sat): using RAW_WINDOW=0 0 12531 12770, dst=0,0,279,284
msDrawRasterLayerGDAL(): red,green,blue,alpha bands = 1,2,3,4
msDrawMap(): Layer 0 (sat), 557.242s
msDrawMap(): Drawing Label Cache, 0.000s
msDrawMap() total time: 557.243s
msSaveImage(/data/temp/Jesper/ttt.png) total time: 0.119s
msFreeMap(): freeing map at 0x7b1f50.
freeLayer(): freeing layer at 0x7ba080.
freeLayer(): freeing layer at 0x7bb760.
shp2img total time: 557.378s
BUT, note 557.378s on the last row...
Also a WMS-request works but takes about 4 minutes to complete!
It looks like I need to reproject all files new GeoTIFFs to get a decent
speed.
Thanks for all the replies!
Jesper
Den tors 3 sep. 2020 kl 13:31 skrev Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi>:
> Hi,
> I would appreciate if you could have a try with
> "gdalwarp -of vrt -t_srs "EPSG:3857" sat.tif sat_3857.vrt"
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Jesper Kempe
> *Lähetetty:* torstai 3. syyskuuta 2020 13.57
> *Vastaanottaja:* Jeff McKenna <jmckenna at gatewaygeomatics.com>
> *Kopio:* Mapserver <mapserver-users at lists.osgeo.org>
> *Aihe:* Re: [mapserver-users] Use Ground Control Points from GeoTIFF
> shp2img creates an empty blank image with a mapfile like this:
> MAP
>     NAME "map"
>     WEB
>         METADATA
>             "wms_title"            "WMS mapserver"
>             "wms_srs"              "EPSG:4326 EPSG:3021 EPSG:9999
> EPSG:3006 EPSG:900913"
>             "wms_extent"           "1225000 6130000 1910000 7675000"
>             "wms_enable_request"   "*"
>             "wfs_enable_request"   "*"
>         END
>     END
>     PROJECTION
>         "init=epsg:4326"
>     END
>     EXTENT 15 60 30 68
>     SIZE 200 200
>     LAYER
>       NAME "sat"
>       DATA "/data/temp/Jesper/sat.tif"
>       TYPE RASTER
>       STATUS DEFAULT
>       METADATA
>                 "wms_title" "sat"
>       END
>     END
> The output from shp2img looks like this:
> $ shp2img -m ttt.map -o /data/temp/Jesper/ttt.png -all_debug 5
> msLoadMap(): 0.003s
> msDrawRasterLayerGDAL(): Entering transform.
> msDrawRasterLayerGDAL(): src=15,10645,15,15, dst=0,0,200,200
> msDrawRasterLayerGDAL(): source raster PL (14.962,10645.462) for dst PL
> (0,0).
> msDrawMap(): Layer 0 (sat), 0.011s
> msDrawMap() total time: 0.011s
> msSaveImage(/data/temp/Jesper/ttt.png) total time: 0.003s
> msFreeMap(): freeing map at 0x1d14f50.
> freeLayer(): freeing layer at 0x1d1d080.
> freeLayer(): freeing layer at 0x1d1e1b0.
> shp2img total time: 0.017s
> If I add:
>       PROJECTION
>         "init=epsg:4326"
>       END
>       EXTENT 17.0473154408269387 62.1606759790530177 27.5792082876237146
> 66.7744046276809797
> shp2img outputs:
> msLoadMap(): 0.003s
> msDrawRasterLayerGDAL(): src=0,0,10474,10717, dst=27,63,140,61
> msDrawRasterLayerGDAL(): source raster PL (-49.554,-33.774) for dst PL
> (27,63).
> msDrawMap(): Layer 0 (sat), 0.025s
> msDrawMap() total time: 0.025s
> msSaveImage(/data/temp/Jesper/ttt.png) total time: 0.004s
> msFreeMap(): freeing map at 0x2453f50.
> freeLayer(): freeing layer at 0x245c080.
> freeLayer(): freeing layer at 0x245d430.
> shp2img total time: 0.033s
> Then the image is shown in ttt.png but is not in the correct place and not
> rotated correctly.
> Any help or ideas are appreciated!
> Thanks
> Jesper
> Den ons 2 sep. 2020 kl 18:23 skrev Jeff McKenna <
> jmckenna at gatewaygeomatics.com>:
> I'm curious what happens when you try to generate a map image from the
> commandline: shp2img -m test.map -o ttt.png -all_debug 5
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-09-02 4:51 a.m., Jesper Kempe wrote:
> > Hi
> > This is the mapfile:
> > MAP
> >      NAME "map"
> >      WEB
> >          METADATA
> >          END
> >      END
> >      PROJECTION
> >          "init=epsg:4326"
> >      END
> >      EXTENT -180 -90 180 90
> >      LAYER
> >        NAME "sat"
> >        DATA "sat.tif"
> >        TYPE RASTER
> >        STATUS ON
> >        METADATA
> >                  "wms_title" "sat"
> >        END
> >        PROJECTION
> >          "init=epsg:4326"
> >        END
> > 27.5792082876237146 66.7744046276809797
> >      END
> > END
> > I have also tried both without PROJECTION in LAYER and with
> > PROJECTION
> >       AUTO
> > END
> > None of them works.
> > EXTENT in the mapfile is taken from Qgis metadata of the layer.
> > Thanks
> > Jesper
> > Den tis 1 sep. 2020 kl 23:41 skrev Steve Lime <sdlime at gmail.com
> > <mailto:sdlime at gmail.com>>:
> >     What does the mapfile look like?
> >     On Tue, Sep 1, 2020 at 10:26 AM Jesper Kempe <jesper.kempe at gmail.com
> >     <mailto:jesper.kempe at gmail.com>> wrote:
> >         Hi
> >         I have a GeoTiff file that gdalinfo presents like this:
> >         gdalinfo sat.tif
> >         Driver: GTiff/GeoTIFF
> >         Files: sat.tif
> >         Size is 10474, 10717
> >         Coordinate System is `'
> >         GCP Projection =
> >         GEOGCS["WGS 84",
> >              DATUM["WGS_1984",
> >                  SPHEROID["WGS 84",6378137,298.257223563,
> >                      AUTHORITY["EPSG","7030"]],
> >                  AUTHORITY["EPSG","6326"]],
> >              PRIMEM["Greenwich",0],
> >              UNIT["degree",0.0174532925199433],
> >              AUTHORITY["EPSG","4326"]]
> >         GCP[  0]: Id=1, Info=
> >                    (0,0) ->
> >         (27.5783052509812,65.9184735836942,229.992792810313)
> >         GCP[  1]: Id=2, Info=
> >                    (524,0) ->
> >         (27.1416007200269,65.9731480840222,172.994255514815)
> >         GCP[  2]: Id=3, Info=
> >                    (1048,0) ->
> >         (26.7005564512604,66.0268770755367,152.994545626454)
> >         GCP[  3]: Id=4, Info=
> >                    (1572,0) ->
> >         (26.257537545879,66.0793551447287,131.994995356537)
> >         GCP[  4]: Id=5, Info=
> >                    (2096,0) ->
> >         (25.8102107755995,66.1308402121171,163.993212723173)
> >         with 482 GCPs.
> >         The file opens ok in Qgis and is located in the right location.
> >         But I can´t in any way get it to show correctly in Mapserver.
> >         Is this possible to do? Or do I have to gdalwarp the file to a
> >         known projection and set the PROJECTION of the layer?
> >         Thanks
> >         Jesper
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200903/1dedd33c/attachment.htm>
More information about the MapServer-users mailing list
