[mapserver-users] Use Ground Control Points from GeoTIFF
Jesper Kempe
jesper.kempe at gmail.com
Wed Sep 2 00:51:46 PDT 2020
Hi
This is the mapfile:
MAP
NAME "map"
WEB
METADATA
"wms_title" "WMS mapserver"
"wms_srs" "EPSG:4326 EPSG:3021 EPSG:9999 EPSG:3006
EPSG:900913"
"wms_extent" "1225000 6130000 1910000 7675000"
"wms_enable_request" "*"
"wfs_enable_request" "*"
END
END
PROJECTION
"init=epsg:4326"
END
EXTENT -180 -90 180 90
LAYER
NAME "sat"
DATA "sat.tif"
TYPE RASTER
STATUS ON
METADATA
"wms_title" "sat"
END
PROJECTION
"init=epsg:4326"
END
EXTENT 17.0473154408269387 62.1606759790530177 27.5792082876237146
66.7744046276809797
END
END
I have also tried both without PROJECTION in LAYER and with
PROJECTION
AUTO
END
None of them works.
EXTENT in the mapfile is taken from Qgis metadata of the layer.
Thanks
Jesper
Den tis 1 sep. 2020 kl 23:41 skrev Steve Lime <sdlime at gmail.com>:
> What does the mapfile look like?
> On Tue, Sep 1, 2020 at 10:26 AM Jesper Kempe <jesper.kempe at gmail.com>
> wrote:
>> Hi
>> I have a GeoTiff file that gdalinfo presents like this:
>> gdalinfo sat.tif
>> Driver: GTiff/GeoTIFF
>> Files: sat.tif
>> Size is 10474, 10717
>> Coordinate System is `'
>> GCP Projection =
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]
>> GCP[ 0]: Id=1, Info=
>> (0,0) -> (27.5783052509812,65.9184735836942,229.992792810313)
>> GCP[ 1]: Id=2, Info=
>> (524,0) -> (27.1416007200269,65.9731480840222,172.994255514815)
>> GCP[ 2]: Id=3, Info=
>> (1048,0) -> (26.7005564512604,66.0268770755367,152.994545626454)
>> GCP[ 3]: Id=4, Info=
>> (1572,0) -> (26.257537545879,66.0793551447287,131.994995356537)
>> GCP[ 4]: Id=5, Info=
>> (2096,0) -> (25.8102107755995,66.1308402121171,163.993212723173)
>> with 482 GCPs.
>> The file opens ok in Qgis and is located in the right location.
>> But I canĀ“t in any way get it to show correctly in Mapserver.
>> Is this possible to do? Or do I have to gdalwarp the file to a known
>> projection and set the PROJECTION of the layer?
>> Thanks
>> Jesper
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200902/76c31301/attachment.html>
