[mapserver-users] Use Ground Control Points from GeoTIFF
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Sep 2 09:23:40 PDT 2020
I'm curious what happens when you try to generate a map image from the
commandline: shp2img -m test.map -o ttt.png -all_debug 5
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-09-02 4:51 a.m., Jesper Kempe wrote:
> Hi
> This is the mapfile:
> MAP
> NAME "map"
> WEB
> METADATA
> "wms_title" "WMS mapserver"
> "wms_srs" "EPSG:4326 EPSG:3021 EPSG:9999
> EPSG:3006 EPSG:900913"
> "wms_extent" "1225000 6130000 1910000 7675000"
> "wms_enable_request" "*"
> "wfs_enable_request" "*"
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT -180 -90 180 90
> LAYER
> NAME "sat"
> DATA "sat.tif"
> TYPE RASTER
> STATUS ON
> METADATA
> "wms_title" "sat"
> END
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT 17.0473154408269387 62.1606759790530177
> 27.5792082876237146 66.7744046276809797
> END
> END
> I have also tried both without PROJECTION in LAYER and with
> PROJECTION
> AUTO
> END
> None of them works.
> EXTENT in the mapfile is taken from Qgis metadata of the layer.
> Thanks
> Jesper
> Den tis 1 sep. 2020 kl 23:41 skrev Steve Lime <sdlime at gmail.com
> <mailto:sdlime at gmail.com>>:
> What does the mapfile look like?
> On Tue, Sep 1, 2020 at 10:26 AM Jesper Kempe <jesper.kempe at gmail.com
> <mailto:jesper.kempe at gmail.com>> wrote:
> Hi
> I have a GeoTiff file that gdalinfo presents like this:
> gdalinfo sat.tif
> Driver: GTiff/GeoTIFF
> Files: sat.tif
> Size is 10474, 10717
> Coordinate System is `'
> GCP Projection =
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> GCP[ 0]: Id=1, Info=
> (0,0) ->
> (27.5783052509812,65.9184735836942,229.992792810313)
> GCP[ 1]: Id=2, Info=
> (524,0) ->
> (27.1416007200269,65.9731480840222,172.994255514815)
> GCP[ 2]: Id=3, Info=
> (1048,0) ->
> (26.7005564512604,66.0268770755367,152.994545626454)
> GCP[ 3]: Id=4, Info=
> (1572,0) ->
> (26.257537545879,66.0793551447287,131.994995356537)
> GCP[ 4]: Id=5, Info=
> (2096,0) ->
> (25.8102107755995,66.1308402121171,163.993212723173)
> with 482 GCPs.
> The file opens ok in Qgis and is located in the right location.
> But I can´t in any way get it to show correctly in Mapserver.
> Is this possible to do? Or do I have to gdalwarp the file to a
> known projection and set the PROJECTION of the layer?
> Thanks
> Jesper
