[mapserver-users] [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
matthew.f.cechini at nasa.gov
Mon Sep 14 07:56:00 PDT 2020
Unfortunately, that’s not the functionality that I’m looking for…
What I want is to support “&STYLES=default” or “&STYLES=blue” query parameters resulting in different styling of the same underlying data.
Thanks,
Matt
Matthew Cechini
Contractor, Science Systems and Applications, Inc.
NASA GIBS Systems/Software Engineer
410.205.6272
From: "Lime, Steve D (MNIT)" <steve.lime at state.mn.us>
Date: Monday, September 14, 2020 at 10:49 AM
To: Matthew Cechini <matthew.f.cechini at nasa.gov>, "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Subject: RE: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
Names aren’t valid (or useful) at the style-level. If you remove those lines it should work and you’ll get stacked styles for each feature. --Steve
From: Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov>
Sent: Monday, September 14, 2020 7:27 AM
To: Lime, Steve D (MNIT) <steve.lime at state.mn.us>; mapserver-users at lists.osgeo.org
Subject: Re: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
We’re using 7.0.1… admittedly a bit of an older version. Mapserver balks on NAME in the STYLE element in that version.
Thanks,
Matt
Matthew Cechini
410.205.6272
From: "Lime, Steve D (MNIT)" <steve.lime at state.mn.us<mailto:steve.lime at state.mn.us>>
Date: Friday, September 11, 2020 at 5:17 PM
To: Matthew Cechini <matthew.f.cechini at nasa.gov<mailto:matthew.f.cechini at nasa.gov>>, "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [EXTERNAL] RE: Multiple Styles for a LAYER/CLASS
Hi Matt: Actually that syntax is supported (except for the style NAME attribute) and you can have multiple styles inside a class. What version are you using? --Steve
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>> On Behalf Of Cechini, Matthew F. (GSFC-423.0)[Science Systems & Applications, Inc.]
Sent: Friday, September 11, 2020 2:37 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Multiple Styles for a LAYER/CLASS
Greetings,
I would like to provide multiple styles for the same LAYER/CLASS in our mapserver configuration. Ideally that looks something like this, though of course this syntax isn’t currently supported.
CLASS
NAME "Thermal Anomalies"
STYLE
NAME 'default'
SYMBOL 'circle'
COLOR 240 40 40
OUTLINECOLOR 240 40 40
SIZE 3
END
STYLE
NAME 'blue'
SYMBOL 'circle'
COLOR 0 0 255
OUTLINECOLOR 0 0 255
SIZE 3
END
END
How would I accomplish this given existing functionality?
Thanks,
Matt
Matthew Cechini
410.205.6272
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200914/48144da1/attachment-0001.html>
