[mapserver-users] Heads-up: start removing all references to DUMP in your mapfiles now...
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Apr 8 09:05:23 PDT 2021
Hello everyone!
This is a big heads-up, that the upcoming 8.0 release (and the current
MapServer source code if you compile from the GitHub [unreleased] source
as of today) will cause an error to be thrown:
   loadLayer(): Unknown identifier.  Parsing error near (DUMP): line xxx
So it would be smart now to review all of your mapfiles to make sure
that any references to DUMP in your layers are commented or removed.
(DUMP was first deprecated back in the 6.0 release, and using LAYER
METADATA is required instead)
This is no small task, as a manager of MapServer services I realize, as
today I upgraded and suddenly all of my OGC services and mapfiles broke
(80+ mapfiles in MS4W, plus all of the live demos, I must have a few
hundred mapfiles to update and check, at least).  I have also begun to
reach out to other various projects/communities today that use
MapServer, so they can start adapting right away; please do the same if
you can.
Thanks all!
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-users mailing list
