[mapserver-users] cgi-bin/mapserv double free error on RHEL 8.2
Worth Lutz wal3 at mindspring.com
Tue Apr 20 05:58:20 PDT 2021
Thanks all for your help.
We found two versions of libproj and two of GDAL. This was due to
PostGIS pulling in newer versions.
PostGIS came from a repository and mapserver was compiled. We are
currently trying to figure out the best way to resolve this.
One other question; Is the old php mapscript and  new swig php mapscript
mutually exclusive?  In other words, do we build MapServer with one or
the other?  That is my guess.
Thanks,
*Worth Lutz*
On 4/16/2021 6:37 PM, Even Rouault wrote:
>> Not sure.  I would also take a look inside your /cgi-bin/ dir and
>> execute: ldd mapserv   (and look for any conflicts with libs) but
>> that's an awful guess, not easy to see (but I've been here before
>> with PROJ/GeoTIFF/Spatialite lib conflicts, in this case I'm not sure
>> what lib).
> I strongly concur with Jeff's suggestion of using ldd mapserv.
> Segmentation fault after the end of a plain & simple "mapserv -v"
> really smells a binary that links to 2 versions of the same lib, and
> clashes during deallocation of static variables (although I would
> expect it to also crash in all situations, but behaviour might be
> quite unprectible). And the usual suspects are indeed the ones listed
> by Jeff.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210420/6adaf6eb/attachment.htm>
More information about the MapServer-users mailing list
