[mapserver-users] Can't see any MVT label / point output with QGIS
Even Rouault even.rouault at spatialys.com
Wed Aug 25 03:25:32 PDT 2021
This was a Mapserver bug. See
https://github.com/MapServer/MapServer/pull/6389
Even
Le 25/08/2021 à 12:21, Yves Jacolin a écrit :
> Hello Ludovic,
> You will probably get more information on the QGIS mailing list as it
> is an issue from QGIS. Which version of QGIS are you using? Did you
> check the error message in the QGIS log panel?
> Y.
> Le ven. 13 août 2021 à 19:08, GNEMMI Ludovic <LGNEMMI at rgd.fr
> <mailto:LGNEMMI at rgd.fr>> a écrit :
>     Hi List,
>     I am trying  MVT output with Mapserver 7.6.
>     Everything works perfectly. But unfortunately I can't display any
>     point/label in QGIS.
>     It’s OK with OpenLayers or even with Maputnik but i don’t see any
>     point/label in QGIS regardless of input data (vector tile layer or
>     pbf file).
>     I also encounter a problem when I convert these PBF output with
>     ogr2ogr. The layer is present. Attributes too but there is no GEOM.
>     I wonder if I missed something or if it’s a bug. Has anyone come
>     across this problem ?
>     I started with the dataset provided with Steve Lime
>     (https://github.com/sdlime/mvt-demo/
>     <https://github.com/sdlime/mvt-demo/>)
>     Thanks for your help
>     Ludovic
>     _______________________________________________
>     mapserver-users mailing list
>     mapserver-users at lists.osgeo.org
>     <mailto:mapserver-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-users
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Yves Jacolin
> Training and support manager - Team Manager
> Camptocamp
> Tel (France) : +33 4 58 48 20 43
> Tel (Switzerland) : +41 21 619 10 43
> Mob. : +33 6 18 75 42 21
> email : yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>
> http://www.camptocamp.com <http://www.camptocamp.com>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210825/81e83b3c/attachment.htm>
More information about the MapServer-users mailing list
