[mapserver-users] MAP Query Parameter
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Wed Aug 18 00:01:25 PDT 2021
Hello Patrick,
the cgi-directory should be the directory, where your mapserver binary
is stored.
BUT have you tried to use the absolute path? As I know, it is always the
absolute path like in
https://live.osgeo.org/en/quickstart/mapserver_quickstart.html#id2
When you're starting with mapserver right know, please read the security
advices Steve mentioned a few month ago:
https://mapserver.org/announcements/2021-03-30-limit-mapfile-access.html
Jörg
Am 18.08.21 um 00:37 schrieb Patrick Young:
> Hello!
> I've been working through the mapserver tutorial where my setup is
> fastcgi using nginx + supervisor running the mapserv process, and the
> two are talking via a unix socket.
> I had been banging my head on a 502 error but finally figured it out
> when I set the map= query parameter to the full, absolute path of the
> mapfile I was trying to use.
> In the docs (https://mapserver.org/cgi/controls.html
> <https://mapserver.org/cgi/controls.html>) it mentions
>> MAP [filename] Path, relative to the CGI directory, of the map file to
> be used.
> I am curious though, what is the "CGI directory" when you're running
> under fastcgi?
> Thanks!
> Patrick
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Aufbau von Geodateninfrastrukturen mit Open-Source-Software
FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021“
Jetzt anmelden: https://foss-academy.com/kompaktkurse/
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
