[mapserver-users] QSTRING HELP
Steve Lime sdlime at gmail.com
Mon Dec 13 18:54:54 PST 2021
1) You didn’t say which version (hopefully latest, greatest) but you should
only need the entry in the validation block. Note an “anything” validation
is not recommended.
2) A qstring with no qitem is interpreted as a MapServer logical expression
I believe, and your example is not a valid expression. What exactly is
returned, I mean, what does empty mean? There might indicate a bug and a
expression parsing error is being suppressed some where.
3) A qitem+qstring is meant to cover a very simple use case. You’d need to
use a plain qstring or even better, WFS to do something more complex.
On Sat, Dec 11, 2021 at 8:54 AM Carlos Neves (LREC) <cneves at lrec.pt> wrote:
> Hi list,
> I need to query and highlite a map in a Mapserver layer using ITEMNQUERY
> 1st -  I have validate qstring for any character
>          METADATA
>              "wms_title" "counties"
>              "qstring_validation_pattern" ".*"
>          END
>          VALIDATION
>             "qstring" ".*"
>          END
> 2nd - I'm not sure, but it seems in Mapserver Manual that  QITEM is an
> option and you can use expressions like "qstring=county_name = New
> York". I have no mapserver return error  but the query allways returns
> empty.
> 3rd - With CGI qlayer=counties&qitem=county_name&qstring=New  it works,
> but i need to use others items  and others search conditions like
> substrings like "New Jersey" or "New York"
> Any help would be appreciated
> Carlos
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211213/a7e8232f/attachment.htm>
More information about the MapServer-users mailing list
