[mapserver-users] Selecting data from multiple OGR layers
Iljya Kalai
iljya.kalai at gmail.com
Wed Feb 3 09:54:33 PST 2021
Hi everyone,
I'm trying to select data from multiple OGR layers and style them based on
the source layer, as well as some attributes that are not common to all
layers.
I discovered the UNION layer
<https://mapserver.org/mapfile/union.html#union> which seems to be the
answer. According to the documentation
<https://mapserver.org/mapfile/union.html#union> the source layer name
should be in the [Combine_SourceLayerName] attribute. However, I get this
error when I try to use it:
msOGRLayerInitItemInfo(): OGR error. Invalid Field name:
Combine_SourceLayerName in layer `LAYER1'
(I also tried [Union:SourceLayerName] which I found in the mapunion.c code
<https://github.com/MapServer/MapServer/blob/0f7bbf67ce7c6fec0feaa0b33033daf02e406b9b/mapunion.c#L39>,
but that gives the same error.)
Map file snippet:
LAYER
NAME "U"
STATUS DEFAULT
CONNECTIONTYPE UNION
CONNECTION "LAYER1,LAYER2"
CLASS
NAME "C1"
EXPRESSION ("[Combine_SourceLayerName]" = "LAYER1")
Any ideas?
Thanks!
Iljya
P.S I'm new here!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210203/a12e4779/attachment.htm>
More information about the MapServer-users
