[mapserver-users] Selecting data from multiple OGR layers
Iljya Kalai iljya.kalai at gmail.com
Wed Feb 3 23:18:04 PST 2021
This worked - thank you!
I was going to update the documentation, but by the time I woke up, Jeff
had beat me to it
<https://github.com/MapServer/MapServer-documentation/commit/0e7c9da79514659b1c879e0fabc91c8104902c04>
Em qua., 3 de fev. de 2021 às 19:16, Tamas Szekeres <szekerest at gmail.com>
escreveu:
> Iljya,
> You might probably try Union_SourceLayerName as the attribute name.
> Best regards,
> Tamas
> Iljya Kalai <iljya.kalai at gmail.com> ezt írta (időpont: 2021. febr. 3.,
> Sze, 18:54):
>> Hi everyone,
>> I'm trying to select data from multiple OGR layers and style them based
>> on the source layer, as well as some attributes that are not common to all
>> layers.
>> I discovered the UNION layer
>> <https://mapserver.org/mapfile/union.html#union> which seems to be the
>> answer. According to the documentation
>> <https://mapserver.org/mapfile/union.html#union> the source layer name
>> should be in the [Combine_SourceLayerName] attribute. However, I get
>> this error when I try to use it:
>>    msOGRLayerInitItemInfo(): OGR error. Invalid Field name:
>> Combine_SourceLayerName in layer `LAYER1'
>>  (I also tried [Union:SourceLayerName] which I found in the mapunion.c
>> code
>> <https://github.com/MapServer/MapServer/blob/0f7bbf67ce7c6fec0feaa0b33033daf02e406b9b/mapunion.c#L39>,
>> but that gives the same error.)
>> Map file snippet:
>> LAYER
>>     NAME "U"
>>     STATUS DEFAULT
>>     CONNECTIONTYPE UNION
>>     CONNECTION "LAYER1,LAYER2"
>>     CLASS
>>        NAME "C1"
>>        EXPRESSION ("[Combine_SourceLayerName]" = "LAYER1")
>> Any ideas?
>> Thanks!
>> Iljya
>> P.S I'm new here!
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210204/318a6e6f/attachment.htm>
More information about the MapServer-users mailing list
