[mapserver-users] Mapscript circular import error inside Python-Flask Docker
Seth G
sethg at geographika.co.uk
Tue Feb 9 00:37:51 PST 2021
Hi Aditya,
Are you building MapScript yourself or using "sudo apt-get install python-mapscript" - see notes under "Installation on Unix" at https://pypi.org/project/mapscript/
"This happens only when I have the Python VENV activated when running outside Docker" - do you mean the exact same approach works outside of Docker? Is MapServer installed on Docker (this is required along with mapscript)?
Python 3.9 is as yet untested/supported, but this may not be the cause issue.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Mon, Feb 8, 2021, at 10:19 AM, aditya kudekar wrote:
> I have a simple flask app and I am trying to run in Docker
> `import mapscript
> from flask import Flask
> import json
app = Flask(__name__)
port = 5000
> @app.route("/hello")
> def geocoder():
epsg = mapscript.pointObj(1, 1)
return json.dumps(epsg)
test()
> if __name__ == '__main__':
app.run(host="0.0.0.0", port=port)
> My Dockerfile is:
> `FROM python
WORKDIR /opt/demo/
COPY /app .
RUN pip install -r requirements.txt
ENTRYPOINT python test.py
> But I get the following error when I run `docker run -p 5000:5000 test:latest`:
> `Traceback (most recent call last):
File "/opt/demo/test.py", line 1, in <module>
import mapscript
File "/usr/local/lib/python3.9/site-packages/mapscript/__init__.py", line 2, in <module>
from .mapscript import *
File "/usr/local/lib/python3.9/site-packages/mapscript/mapscript.py", line 13, in <module>
from . import _mapscript
ImportError: cannot import name '_mapscript' from partially initialized module 'mapscript' (most likely due to a circular import) (/usr/local/lib/python3.9/site-packages/mapscript/__init__.py)
> This happens only when I have the Python VENV activated when running outside Docker but I don't know why I am getting this error inside Docker.
> Warm Regards
> Aditya Rajendra Kudekar
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210209/68d7659e/attachment.htm>
More information about the MapServer-users
