[mapserver-users] PostgreSQL authentication method.
Steve Lime sdlime at gmail.com
Thu Feb 18 13:49:29 PST 2021
I wonder if that's more a function of the PostgreSQL client library
version/capabilities. Do you know what MapServer is compiled against? You
might try connecting to your database with psql as another test of the
client lib.
On Thu, Feb 18, 2021 at 2:25 PM Moen, Paul T. <pmoen at nd.gov> wrote:
> I recently tried a Mapserver layer connected to a PostgreSQL 13.2 database
> that had password_encryption = scram-sha-256.  I was unsuccessful in
> getting it to work until I switched it to md5 and reset the passwords.  The
> following error was logged and the interesting part seems to be
> (authentication method 10 not supported).
> [Thu Feb 18 13:57:02.652879 2021] [php7:warn] [pid 16668] [client
> 192.168.100.4:57341] PHP Warning:  mapObj::drawQuery(): [MapServer
> Error]: msPostGISLayerOpen(): Database connection failed. Check server logs
> for more details.Is the database running? Is it allowing connections? Does
> the specified user exist? Is the password valid? Is the database on the
> standard port?\n in /Volumes/Data/WebServer/newswc/php/drawmappm.php on
> line 243, referer: http://stagmapservice.swc.nd.gov/
> Database connection failed (authentication method 10 not supported
> ) with connect string 'user=dauser password=****** dbname=swc
> host=dadatabase.blah.blah.blah port=5432'
> Is the database running? Is it allowing connections? Does the specified
> user exist? Is the password valid? Is the database on the standard port? in
> msPostGISLayerOpen()msPostGISLayerOpen(): Query error. Database connection
> failed. Check server logs for more details.Is the database running? Is it
> allowing connections? Does the specified user exist? Is the password valid?
> msDrawMap(): Image handling error. Failed to draw layer named 'Countries -
> Natl Atlas'.
> Is this an issue with MapServer?  If so, will scram-sha-256 authentication
> be supported by Mapserver?
> Thanks,
> Paul
> MapServer version 7.6.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M SUPPORTS=PBF INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210218/9634bb91/attachment.htm>
More information about the MapServer-users mailing list
