[mapserver-users] Labels colliding with symbols
Iljya Kalai iljya.kalai at gmail.com
Thu Feb 18 14:58:46 PST 2021
Thanks Lars! Based on your workaround, it seems to me that line labeling
works something like this:
  1. candidate positions are computed along the line using repeat distance
and other factors
  2. the candidate positions that are not possible due to collisions with
other labels are excluded (unless force is set)
I tried to confirm this hypothesis by looking at the code, but being new to
MapServer, I can't be sure. However, I did find the code that does step 1:
https://github.com/MapServer/MapServer/blob/20b7671f788952c6097ae154b667dd564cf70764/mapprimitive.c#L1956
So it's likely that I'm not far from the truth.
For my particular use case, I would like to label the line just once,
certainly not many times. For this, it would be helpful to compute
candidate placements once the restrictions on positioning are known. Is
there any way to accomplish this currently?
Thanks,
Iljya
Em qui., 18 de fev. de 2021 às 10:57, <lars.schylberg at blixtmail.se>
escreveu:
> Hi,
> I have modified your example a little bit.
> I You add REPEATDISTANCE for the text and then a fake label with
> transparent text above the svg symbol
> I think that You get something that is close to what you are looking for.
> If You remove the last fake label block You get the old behavior that the
> text is written above the symbol.
> I have inserted the code in your GIST:
> https://gist.github.com/iljya/b1d58f250be11e8972ea6e5628f84b2a
> I have been experimenting without repeatdistance and I can agree with You
> that the results were strange.
> I thought that the fake label would do the trick, but it didn't
> /Lars Schylberg
> 17 februari 2021 kl. 20:05, "Iljya Kalai" <iljya.kalai at gmail.com
> <iljya.kalai at gmail.com?to=%22Iljya%20Kalai%22%20%3Ciljya.kalai at gmail.com%3E>>
> skrev:
> Hi Steve,
> I've created a minimal example to demonstrate the issue:
> Thanks for your help,
> Iljya
> Em ter., 16 de fev. de 2021 às 20:41, Steve Lime <sdlime at gmail.com>
> escreveu:
> Hmmm... Point symbols are automatically considered as part of label
> placement and collision detection. Since they are drawn first, their
> placement is cached and labels are placed around them. Can you share
> specifics on your layers and symbols - perhaps a small test case? --Steve
> On Tue, Feb 16, 2021 at 4:28 PM Iljya Kalai <iljya.kalai at gmail.com> wrote:
> Hi,
> On my map, labels sometimes overlap symbols. Is there a way to avoid this,
> or are only label/label conflicts avoided? I tried both CC and AUTO for
> LAYER::CLASS::LABEL::POSITION.
> https://i.imgur.com/C9Ir7dA.png
> Thanks!
> Iljya
> *# *Map file extract
> LAYER
> NAME "LINE"
> TYPE LINE
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 1
> END
> LABEL
> COLOR 150 150 150
> TYPE truetype
> SIZE 10
> ANGLE AUTO
> POSITION CC
> TEXT "hello"
> END
> END
> END
> LAYER
> NAME "SYMBOLS"
> TYPE POINT
> CLASS
> STYLE
> SYMBOL "ABC"
> END
> END
> END
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210218/5429b34c/attachment.htm>
More information about the MapServer-users mailing list
