[mapserver-users] Selecting data from multiple OGR layers
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Feb 3 13:58:22 PST 2021
Thanks Iljya and Tamas, I have confirmed that the documentation was
outdated, and has now been fixed as recommended by Tamas.
Iljya: I tested successfully with:
EXPRESSION ("[Union_SourceLayerName]" = "LAYER1")
and welcome to the MapServer community! :)
-jeff
Jeff McKenna
GatewayGeo: MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-02-03 2:16 p.m., Tamas Szekeres wrote:
> Iljya,
> You might probably try Union_SourceLayerName as the attribute name.
> Best regards,
> Tamas
> Iljya Kalai <iljya.kalai at gmail.com <mailto:iljya.kalai at gmail.com>> ezt
> írta (időpont: 2021. febr. 3., Sze, 18:54):
> Hi everyone,
> I'm trying to select data from multiple OGR layers and style them
> based on the source layer, as well as some attributes that are not
> common to all layers.
> I discovered the UNION layer
> <https://mapserver.org/mapfile/union.html#union> which seems to be
> the answer. According to the documentation
> <https://mapserver.org/mapfile/union.html#union> the source layer
> name should be in the [Combine_SourceLayerName] attribute. However,
> I get this error when I try to use it:
> msOGRLayerInitItemInfo(): OGR error. Invalid Field name:
> Combine_SourceLayerName in layer `LAYER1'
> (I also tried [Union:SourceLayerName] which I found in the
> mapunion.c code
> <https://github.com/MapServer/MapServer/blob/0f7bbf67ce7c6fec0feaa0b33033daf02e406b9b/mapunion.c#L39>,
> but that gives the same error.)
> Map file snippet:
> LAYER
> NAME "U"
> STATUS DEFAULT
> CONNECTIONTYPE UNION
> CONNECTION "LAYER1,LAYER2"
> CLASS
> NAME "C1"
> EXPRESSION ("[Combine_SourceLayerName]" = "LAYER1")
> Any ideas?
> Thanks!
> Iljya
> P.S I'm new here!
