[mapserver-users] Error/ false colored image with GetMap
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Feb 26 00:21:53 PST 2021
Hi Charly,
it works (debian and ubuntu....) have you tried to switch it off and on
again? ;)
http://schulung.foss.academy/cgi-bin/mapserv?map=/data/charly/rheinek.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=440663,5538120,452197,5543810&CRS=epsg:25832&WIDTH=823&HEIGHT=406&LAYERS=ug_test&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
http://schulung.foss.academy/cgi-bin/mapserv?map=/data/charly/rheinek.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=440663,5538120,452197,5543810&CRS=epsg:25832&WIDTH=823&HEIGHT=406&LAYERS=ug_test&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
Two ideas:
what about the OUTPUTFORMAT blocks? Do you need them? perhaps there's a
problem with your AGG driver in your installation
my first thought pointed at your apache config, "the
> image can't be displayed cause it contains errors" looks like a wrong
mime-type provided by the apache.
also your jpeg_error.jpg looks more like an display-error.
The console-output (-v) looks O.K., you forgot to pipe the output into
a file ('> test.png')
How did you install mapserver and webserver? ms4w? gisinternals?
regards from Berlin, Jörg
Am 26.02.21 um 07:15 schrieb Toma, Charlotte:
> Hello,
> I need your help…
> I installed mapserver on windows server and tested the installation
> successful. The console output from „mapserv –v“ looked like it should
> and my GetCapabilities worked fine. Then I tested the GetMap and
> GetLegend from my test-WMS and it isn’t working correctly. The requests
> gives me a false coloured picture with jpeg and an error with png "the
> image can't be displayed cause it contains errors" (or so in german). I
> never saw something like this and after my research in the internet I
> still don’t know what to do…
> The test with „shp2img -m E:/mapserv_ows/rheinek.map -o test.png
> -layer_debug ug_test 5“ worked fine and I got the corret result as an
> image (jpeg and png); but only after I added the „SIZE“ parameter in my
> mapfile. Until this I got the error „dimensions not defined / can’t be
> calculated“.
> My mapfile is very simple, cause i wanted to test if it works (one
> shapefile, one polygon, simple red fill and black outline to display).
> In the following cloud folder you can see my mapfile, the weird
> jpeg-GetMap answer and the error message:
> https://my.hidrive.com/lnk/jrySL9oJ
> Greetings
> Charly
> Mit freundlichen Grüßen
> im Auftrag
> Charlotte Toma
> Landeshauptstadt Wiesbaden
> -Der Magistrat-
> Stadtplanungsamt
> -610230-
> Gustav-Stresemann-Ring 15
> 65189 Wiesbaden
> Tel.: 0611 31-3436
> Fax: 0611 31-3917
> E-Mail: 61GIS at wiesbaden.de <mailto:61GIS at wiesbaden.de>
> Internet: www.wiesbaden.de <http://www.wiesbaden.de/>
> Jede nicht gedruckte Seite spart Holz, Wasser und Strom.
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Viele Grüße,
Jörg Thomsen
Einladung zum
Mapbender Anwendertreffen
online am 25.03.2021
https://mapbender.org
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
