[mapserver-users] Mapserver 7.6.2
Stephane Poissant
spoissantca at gmail.com
Wed Jan 6 05:41:29 PST 2021
I’ll give a try to 1.70 (compile)
The reason is that I cannot use 1.53 as it does not compile for the previously mentioned error with boost.
Even if I install (from repo) boost169) it installs almost everything but not de -devel has it breaks dependancies.
So using 1.75 was my first test. I am now trying 1.70. Fingers crossed it will work.
Would you have a specific version recommendation for the software stack?
(Without compilation)?
In any cases, I have to go with what I have in the repos available.
I’ve been trying for quite sometime to find the right combination without success. Your input would be
Helpful to me.
Regards,
SP
Stéphane Poissant
spoissantca at gmail.com <mailto:spoissantca at gmail.com>
> On Jan 6, 2021, at 1:54 AM, Eichner, Andreas - SID <Andreas.Eichner at sid.sachsen.de> wrote:
> Good morning,
> //opt/boost/lib/libboost_serialization.so.1.75.0: undefined reference to `std::uncaught_exceptions()@GLIBCXX_3.4.22'
> collect2: error: ld returned 1 exit status
> it seems that libboost_serialization is build against a different (newer) libstdc++ as is used during the MapServer build.
> I'd suggest to use the distribution provided boost libraries (v1.53) and the system's default compiler packages (wich includes libstdc++).
> HTH
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210106/4750db56/attachment.htm>
More information about the MapServer-users
