[mapserver-users] Mapserver 7.6.2
Stephane Poissant spoissantca at gmail.com
Thu Jan 7 11:39:53 PST 2021
Good day Andreas,
Your suggestion about replacing boost packages from AWS with CentOS ones worked.
Good catch. I was able to finally compile and install all my requirements. Thumbs up!
I had to download the whole list and install using rpm -ivh *.rpm.
One more thing.
I am able to render many tiles (images) but I have trouble with some others. I double checked for librairies to avoid having duplicates or many versions...
But it does not seem to be the case.
I am getting a bunch of the following in my apache logs:
#### (Some data was replaced with xxxx on purpose for security reasons in the below log output) ###
[cgi:error] [pid 2512] [client 10.2.10.155:60456] AH01215: GDAL: GDALOpen(PG:host=xxxxxxxx.com port=xxxx dbname=‘xxxxxx' user=‘xxxxx' password=XXXXXXXXXXXXXXXXXXXXXX schema='public' table=‘xxxxxx' mode='2', this=0x125df80) succeeds as PostGISRaster.: /var/www/html/map/mapserv.cgi, referer: http://xxxxx.com/
[cgi:error] [pid 2509] [client 10.2.10.155:60451] AH01215: GDAL: GDAL_CACHEMAX = 388 MB: /var/www/html/map/mapserv.cgi, referer: http://xxxxx.com/
…//snip//...
AH01215: GDAL: In GDALDestroy - unloading GDAL shared library.
What could cause that? Flags while doing cmake? (Python maybe)
(I am using the below one):
cmake -Wno-dev -DCMAKE_PREFIX_PATH="/usr/proj72/;/usr/pgsql-12/;/usr/gdal32;/usr/geos39/" -DWITH_PYTHON=0 -DWITH_JAVA=1 -DWITH_THREAD_SAFETY=1 -DWITH_FRIBIDI=1 -DWITH_FCGI=0 -DWITH_EXEMPI=0 -DWITH_GIF=0 -DWITH_FCGI=0 -DWITH_PROTOBUFC=0 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_KML=1 -DWITH_SOS=1 -DCMAKE_BUILD_TYPE=Release ..
— Stéphane
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210107/20631bd1/attachment.htm>
More information about the MapServer-users mailing list
