[mapserver-users] restful GFI request from Mapproxy
Kulawik, Robert
KulawikR at eba.bund.de
Thu Jan 28 08:01:12 PST 2021
Dear List,
I have a issue between Mapproxy 1.12.0 and Mapserver 7.4.3 with GetFeatureInfo (GFI) restful requests
I don´t know if this ist a Mapproxy or Mapserver problem, maybe has someone a solution for this issue.
When I use the WMS(?) KVP Capabilities from Mapproxy (http://localhost/mapproxy/service?REQUEST=GetCapabilities) in e.g. QGIS, everything works fine. The GetFeatureInfo (GFI) is available and working for the WMTS Layer.
The KVP GFI request is similar as in Mapserver WMS,
http://localhost/mapproxy/service?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=359590.9848198993713595,5668915.14138658251613379,361421.80612308223498985,5670043.28831636067479849&CRS=EPSG:25832&WIDTH=568&HEIGHT=350&LAYERS=verkehrsweg_wmts&STYLES=&FORMAT=image/png&QUERY_LAYERS=verkehrsweg_wmts&INFO_FORMAT=text/html&I=268&J=176&FEATURE_COUNT=10
http://localhost/cgi-bin/mapserv64/mapserv.fcgi?map=c:/srv/mapfiles/verkehrswege.map&language=ger&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&BBOX=359590.9848198993713595,5668915.14138658251613379,361421.80612308223498985,5670043.28831636067479849&SRS=EPSG:25832&WIDTH=568&HEIGHT=350&LAYERS=Verkehrsweg&STYLES=&FORMAT=image/png&QUERY_LAYERS=Verkehrsweg&INFO_FORMAT=text/html&X=266&Y=176&FEATURE_COUNT=10
When I use the restful Mapproxy Service ( from http://localhost/mapproxy/wmts/1.0.0/WMTSCapabilities.xml or http://localhost/mapproxy/service?REQUEST=GetCapabilities&SERVICE=WMTS ), no GFI works
When I request the restful service, the restful tile request works
http://localhost/mapproxy/wmts/verkehrsweg_wmts/wmtsgrid/09/146/324.png
but the GFI request on the same tile not
http://localhost/mapproxy/wmts/verkehrsweg_wmts/wmtsgrid/09/146/324/38/142.html
restful_template: '/{Layer}/{TileMatrixSet}/{TileMatrix}/{TileCol}/{TileRow}.{Format}'
restful_fi_template: '/{Layer}/{TileMatrixSet}/{TileMatrix}/{TileCol}/{TileRow}/{I}/{J}.{Format}'
Mapserver says:
msQueryByPoint(): Search returned no results. No matching record(s) found.
Either the Request
http://localhost/mapproxy/service?SERVICE=WMTS&REQUEST=GetFeatureInfo&VERSION=1.0.0&LAYER=verkehrsweg_wmts&STYLE=default&INFOFORMAT=text/html&FORMAT=image/png&TILEMATRIXSET=wmtsgrid&TILEMATRIX=10&TILEROW=511&TILECOL=171&I=168&J=214
earn the same Mapserver error.
Unfortunally I can´t see the request from Mapproxy to Mapserver in my logs.
Does Mapserver support this restful request format? Any ideas?
My Mapproxy yaml configuration:
services:
wmts:
restful: true
# with or without both templates the same behavior
featureinfo_formats:
- mimetype: application/gml+xml; version=3.1
suffix: gml
- mimetype: text/html
suffix: html
kvp: true
md:
title: mytitle
access_constraints: "GeoNutzV"
fees: keine
contact:
organization: myorg
position: owner
wms:
srs: ['EPSG:4258','EPSG:4326','EPSG:31466','EPSG:31467','EPSG:31468','EPSG:31469','EPSG:25831','EPSG:25832','EPSG:25833']
image_formats: ['image/png', 'image/jpeg']
max_output_pixels: [5000, 5000]
md:
title: mytitle
fees: keine
contact:
organization: myorg
position: owner
sources:
verkehrsweg_source:
type: wms
wms_opts:
featureinfo: true
version: 1.1.1
legendgraphic: true
legendurl: 'http://localhost/cgi-bin/mapserv64/mapserv.fcgi?map=c:/srv/mapfiles/verkehrswege.map&language=ger&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=Verkehrsweg&format=image/png&STYLE=default'
supported_srs: ['EPSG:25832']
concurrent_requests: 4
##seed_only: true
coverage:
bbox: [204485, 5204122, 1008600, 6134557]
srs: 'EPSG:25832'
req:
url: http://localhost/cgi-bin/mapserv64/mapserv.fcgi?map=c:/srv/mapfiles/verkehrswege.map
layers: Verkehrsweg
format: image/png
In Mapserver Layer Metadata ist anything enabled in my opinion
"wms_enable_request" "*"
"ows_enable_request" "*"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
"WMS_FEATURE_INFO_MIME_TYPE" "application/gml+xml; version=3.1"
"WMS_FEATURE_INFO_MIME_TYPE" "application/vnd.ogc.gml"
#or
"wms_getfeatureinfo_formatlist" "text/html,application/gml+xml; version=3.1,application/vnd.ogc.gml"
"gml_include_items" "all"
"ows_include_items" "all"
"wms_include_items" "all"
"WMS_EXTENT" "204485 5204122.33 1008600.36 6134557.66"
"WMS_SRS" "EPSG:25832 EPSG:3857 EPSG:25831 EPSG:25833 EPSG:4326 EPSG:31466 EPSG:31467 EPSG:31468 EPSG:31469 EPSG:4258 EPSG:3038 EPSG:3039 EPSG:3040 EPSG:3041 EPSG:3042 EPSG:3043 EPSG:3044 EPSG:3045 EPSG:3046 EPSG:3047 EPSG:3034 EPSG:3035"
"wms_inspire_metadataurl_format" "application/vnd.ogc.csw.capabilities.response_xml"
"wms_metadataurl_format" "text/xml"
"wms_metadataurl_type" "TC211"
Thanks in advance,
Robert
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210128/4ed4dc7a/attachment.html>
