[mapserver-users] OIDS in postgresql Postgis
Magnus Askaner magnus at internaut.se
Thu Jul 8 01:54:03 PDT 2021
Support for OIDS has been dropped from Postgresql in recent versions.
After postgresql upgrade, trying to select a feature from a Postgis
postgresql table gives an error  in postgresql logs: (sensitive info
redacted)
> 2021-07-08 08:05:45.756 UTC [2270616] user_name at db ERROR:  column
> "oid" does not exist at character 70
> 2021-07-08 08:05:45.756 UTC [2270616] user_name at db HINT: Perhaps you
> meant to reference the column "[table_name].gid".
> 2021-07-08 08:05:45.756 UTC [2270616] user_name at db STATEMENT: select
> "[column_name]"::text,ST_AsBinary(ST_Force2D("the_geom"),'NDR') as
> geom,"oid"::text from [table_name] where "the_geom" &&
> ST_GeomFromText('POLYGON(([....]))',find_srid('','[table_name]','the_geom'))
> and ([column_name]='value')
It seems like mapserver still tries to look up oids.
 From earlier documentation I have got the impression that mapserver
depends on oids when selecting from a postgis table.
Could this be avoided?
Calling mapserv cgi with wget gives "Missing Schema".
The connection string works.
Versions:
$ mapserv -v
MapServer version 7.4.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Postgreql:
version(): PostgreSQL 12.7 (Ubuntu 12.7-0ubuntu0.20.04.1) on
x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04)
9.3.0, 64-bit
POSTGIS_full_version() : POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120"
GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.3.1" LIBXML="2.9.4" LIBJSON="0.13.1"
LIBPROTOBUF="1.3.3" WAGYU="0.4.3 (Internal)"
More information about the MapServer-users mailing list
